Home Forum Ask A Member mercury fuel tanks
  • #1514
    opposedtwin
      US Member - 2 Years
      this is the 2nd mercury tank I have found with the little trigger broken off for whatever reason. are they prone to getting stuck? I am soaking it now but are there any tricks I should be aware of? the primer is stuck as well. I’m not sure why this stuff is stuck. I have done a number of OMC tanks with way!! smellier gas and haven’t had these issues before.
      what’s your view of these tanks? anything I should be aware of?
      thanks for any help!
      scott
      #16219
      dave-bernard
        that is a single line tank. good thing. just use a line with a primer bulb and forget the trigger. I may have a NOS pickup. the pickup has a check valve in it so make sure it is working and clean.
