Home Forum Ask A Member Recharge Caille magnets
  • #1480
    hugh
      The magnets seem to be a bit weak on this one. Can this be recharged? I will most likely put it all together and see if the spark is better than before. I checked everything else and cleaned the points. Just want to know if this type can be recharged if I need it.
      #15936
      The Boat House
        Yes they can be but give it a chance
        to see if the really need to be recharged.
        As a magneto generates more power the faster it spins
        if it starts easily there OK. If it is hard starting or you
        can’t get it started recharging may help.
        As generating electricity would be similar too
        the recharging possess I suspect that if you can get
        them running they will recharge themselves
        #15945
        hugh
          O K Tubs, I plan on having it all done in a week or two, except for painting the tank, that always take me a while.
          #15946
          The Boat House
            I’d be glad to charge them for ya
            but were 1801 miles apart.
            If it was only 1800 miles. 🙄
            #15998
            hugh
              That is a bit far. I am hoping that the compression comes up a little. Can’t check it because of the hole size, but it didn’t feel too strong. I found both rings stuck on about 1/2 of the piston. Everything cleaned up and working free now.
