Home Forum Ask A Member Replacement muffler can for 1924 BNL 2hp Johnson
  • #289442
    Monte NZ
      International Member
      Hi All. My next problem with the above motor,is the muffler can is missing and I was wondering what you would suggest as a replacement?
      Thanks in advance for your help.
      Monte NZ
      #289461
      stanley
        US Member - 2 Years
        Google “oddjobmotors.net” then find Tech tip#3. Good directions for do it yourself.
        #289502
        Monte NZ
          Thanks Stanley very much for your suggestion…….I have just had a look at that website…..excellent!
          Thanks again
          Monte NZ
          #289507
          stanley
            US Member - 2 Years
            One more thing.When I make a new outer can, I cut the length (becomes dia.) long enough to lap the ends.Then I seal and copper rivet the lap.This allows you to get a perfect fit and avoids making the original lock joint.Install with seam facing down and slightly turned towards front and it will work and look perfectly.
            #289538
            Monte NZ
              Thanks Stanley very much for your suggestion…….sounds good!
              Any suggestions regarding the material to seal the lap joint?
              I was thinking of using Silfos to seal and hold the lap.
              Thanks again
              Monte NZ
              #289546
              bkrsdoz
                I have some extra brass outer cans I had purchased from an AOMCI member years ago. If you still need one. Contact me if you like. Bob
                #289550
                Monte NZ
                  Thanks very much bkrsdoz for your very kind offer. Unfortunately postage to NZ is now ridiculously high and I would also be worried about it being damaged as it is fairly fragile……one of the problems of living at the “bottom of the world”, so I think I will have a go at making one and see how it turns out…….I will let you know how I get on.
                  Thanks very much once again.
                  Monte NZ
