Home Forum Ask A Member Well, the Fastwin is "running"
  • This topic has 19 replies, 8 voices, and was last updated 11 years ago by Anonymous.
  • #18154
      It is a pretty simple job really. You may end up needing a new base gasket as well if it tears up when you pop off the pwerhead.
      Yes, seals very easy to get. If you get stuck PM me. I stock a lot of them usually!
      #18163
      richardg
        Regarding it running hot- Mine had a filthy triangular baffle Screen in the water discharge that prevented the water from discharging properly. I slid it out (and left it out) and now it seems to run cool.
        #18168
        mr-asa
          Found the part numbers, 0321467 from OMC, or 18-2060 from Sierra, about a $5 difference per seal.
          When I was able to get it running it stayed cool. I disassembled everything and blew out the tower and powerhead, and took apart the waterpump and re-checked everything. Nothing I could tell came out when I blew everything out with an air hose, pump impeller still looked good. I dunno, what was causing the heat issue, but it seems to be gone now.
          #18170
            Sorry thought I posted the part number!
            See my thread about crank seals. There are a few that will work.
            #18616
            mr-asa
              Well… I took the powerhead off and changed the seals. Now she doesn’t run.
              I didn’t disassemble any of the ignition plate. Just pulled the seals and re-installed ’em. When I pulled the plate off I cleaned the mounting ring of old grease and applied some new grease.
              Anyone think of anything weird I might’ve done? About the only thing I can think of is that the grease might be acting as an insulator between the mount and the ignition ring, preventing a good electrical circuit.
              #18645
                Does it have spark? Start there.
                You may have gotten dirt/grease on the points. Even fingerprints limit spark.
                Whenever you pull a mag plate, take the time to first dress and clean the points, then re set them. Before re installing the flywheel.
                I also test spark, before I torque down the flywheel. We have all been there.
                Just a thin smear of grease under there as well!
                #18663
                seakaye12
                  Which one of the three elements are missing? Spark Fuel or Compression. You have to just start from the beginning and test.
                  BTW…..got your spark plug leads on the correct plug? Been there and done that. Boy was my "pulling arm" sore that day 🙂
                  #18668
                  mr-asa
                    I need to get a spark tester. It’s acting like it’s got at least a partial spark (you know how you can tell that it sort of wants to turn over mid-pull?) I’ll check the points again, but I didn’t remove the plug wires from the plugs. I didn’t actually remove anything but those 4 screws that hold it to the the hold-down ring and the linkage on the throttle arm.
                    I can’t see how the fuel and compression would change.
                    #18686
                      yeah Im willing to bet you have no spark. They will need cleaning, and re set.
                      #18700
                        ASA
                        Make sure You didn’t knock the points out of alignment when you put
                        the plate over the point cam.
                        Good Luck.
                        Steve A W
