Home Forum Ask A Member Firestone Crankcase sealer
  • #1453
      Getting ready to button up the crankcase on my 1950 Firestone 5hp
      soon, and realized that there’s no gasket between the crankcase
      halves, therefore I need sealer.
      Scott manual refers to Permatex 3 and Aviation Grade Permatex,
      but I think they’re the same thing.
      I see there still is a Permates 3 produced. (add below)
      Small container is about $8 bucks.
      Would the product below be okay, or should I look for
      an OMC product?
      Thanks, Buccaneer
      Permatex 80017 Aviation Form-A-Gasket No. 3 Sealant
      Slow-drying, non-hardening brush-top sealant
      Resists gasoline, oil and grease
      Approved for use in aviation as well as automotive applications
      Suggested Applications: Close-fitting machined surfaces, sealing hoses, solid gaskets
      Temperature range of -65F to 400F
      legendre
        That should be just fine, as should a material like Yamabond 4 (and its Three-Bond equivalent) or the Permatex Ultra Grey. The Yamaha / Three-Bond is the same type of sealant used by all of the Japanese motorcycle manufacturers to seal gasket-less engine cases. The Ultra Grey is an RTV material that’s spec’d by many current auto manufactures for similar applications, though it’s also used along with gaskets (such as on a valve cover).
        My experience with the Permatex Aviation sealant, is that it tends to be a little on the thin side, and also sets up a bit more firm than the description might suggest. That is, it behaves more like a glue than I’d like.. but it should still be OK for anything you don’t plan to pull apart anytime soon.
        (Your experience may vary)
        #15654
          Thanks Legendre for you thoughts and time!
          The Boat House
            • This reply was modified 6 years ago by The Boat House.
            • This reply was modified 3 years, 9 months ago by The Boat House.
            #15660
            49hiawatha
              So Tubs what is your backup stuff for fuel line fitting??
              #15662
              The Boat House
                I dug it out of the trash to be
                sure and the part number is 80019
                and doesn’t have a No.3 on what I have.
                I need to try what you have found.
                49Hiawatha I’m sending you a PM.
                #15665
                  quote 49Hiawatha:
                  I use Blue Loc Tite after taking Franks advice years ago.
                  #15686
                    It looks like the only difference between the Permatex Aviation sealant 80017
                    and 80019 is the size of the tube / container.
                    I did find this spec for it that has me wondering if I want to use it…
                    "Chemical / Solvent Resistance – This product retains effective properties
                    in contact with water, ethylene glycol, non-ethanol containing gasoline…."
                    So far I’m still able to buy non-oxygenated gasoline, but who knows in the
                    future.
                    Is the OMC sealer ethanol proof?
                    Thanks, Bucc
                    legendre
                      quote Buccaneer:
                      Thanks, Bucc
                      I can’t answer that question, but the Yamabond 4 / Three-Bond and Permatex Ultra Grey products don’t seem to care one bit about any solvents, oils or fuels, so far as I’ve ever known.
                      And FYI, I use yellow Teflon plumber’s tape to seal fussy copper & brass flare nut connections. At first, I add a couple turns to the threads.. and if that doesn’t seal it (it does, 90% of the time) then I add a single layer to the seating surface itself. Never had it fail, but as ever, YMMV.
                      #15707
                      The Boat House
