Home › Forum › Ask A Member › 1940 Handitwin Point Insulating Bushing 171186
- This topic has 14 replies, 6 voices, and was last updated 7 months, 3 weeks ago by T….in Wisconsin.
March 27, 2024 at 9:21 pm #286310
Looking for ideas on replacement options for a broken points insulating bushing.
T..
March 27, 2024 at 9:59 pm #286315Would a layer or two of shrink tubing work?
March 27, 2024 at 10:47 pm #286316
Get measurements and search eBay – Granger
– McMaster Carr – exct. Should be able to find
something with the correct outside dia. that you
can drill out and/or shorten.
Tubs1 user thanked author for this post.
March 28, 2024 at 6:16 am #286340Grainger has these in stock locally for pick up tomorrow.
$2.00/10 pk
Spacer: For #4 Screw Size, Nylon, Plain, 1/4 in Overall Lg, 0.115 in Inside Dia, 10 PK
Item 3YAE7Mfr. Model 13SP006Product Details
Catalog PageN/ABrandAPPROVED VENDORSystem of MeasurementInchFor Screw Size#4Overall Length Tolerance+/-0.005 inOverall Length1/4 inSpacer TypeRoundMaterialNylonFinishPlainColorWhiteInside Diameter0.115 inInside Diameter Tolerance+/-0.005 inOutside Diameter0.1875 inOutside Diameter Tolerance+/-0.015 inDisplay Qty10Display Sell UOMPKManufacturer Part Number13SP006UNSPSC31161816Country of OriginUSA (subject to change)<dl class=”iYMkrn”>
<dd class=”rOM8HV Qn7Scf”></dd>
</dl><aside class=”foJU3n” aria-label=”Purchase options, Documents, Compliance and Restrictions”>
<form novalidate=”” data-testid=”add-to-cart-form-3YAE7″></form>
</aside>
March 28, 2024 at 9:14 am #286341Maybe the plastic supply lines from faucets in you home! Plastic air lines that are used on truck air brake systems? Maybe the nylon handle on a spatula, you could drill a hole in it then grind down the outside. Put your thinking cap on and think out of the box, you might stumble on something that will work!
dale
March 28, 2024 at 2:06 pm #286342I was thinking the same thing, 1/4″ cooler water tubing or ??? Try home dept maybe. I know it’s tiny tubing try a plastic tubing supplyer in town.
March 28, 2024 at 5:11 pm #286353Dont’ over think this,,, it’s a non-technical part, only keeps the side of the screw from contacting the metal bore. If you still have the other half of the broken sleeve, put it back in the bore. … even a few wraps of tape will do the job.
Joe B
March 28, 2024 at 5:36 pm #286355Posted @ 6:16 this morning.
I ordered a pack of 10 from Grainger with the correct ID & OD x .25L. for $2.00
I’ll cut to length.
Thanks Tubs
March 28, 2024 at 11:02 pm #286370
The internet is definitely our friend when looking
for something to substitute a part no longer available.
Except for having to order them everything fell
right into place for you this time – if you actually get
them. I have an ever growing pile of stuff that
wasn’t what I ordered. Having the suppler local
is a big plus when there is an issue.
TubsMarch 30, 2024 at 11:07 am #286403Nylon bushing from Grainger (3YAE7) worked well. OD & ID are a good fit, I only had to trim to length (.150″).
Verify that your cut length does not protrude above the surface of point housing as to restrict contact of the 2 exterior plates when assembled. I probably should have took pictures but I think this will be apparent when assembling.
Should anyone need a few of these nylon bushings PM me and I’ll mail them to you.
T.. in Wisconsin
