Home Forum Ask A Member 1928 Johnson A-35 questions
Viewing 10 posts - 11 through 20 (of 68 total)
  • #285197
      Tubs, hard to believe that’s the same motor……
      that one turned out great!
      labrador-guy
        That ain’t the same motor?   Are you pulling our leg Mr Tubs?
        dale
        #285205
          Well Dale, I was in the Army, and if you were in any
          service, you know how the story can sometimes
          get exaggerate a bit!!! But I ain’t lyin this time.
          #285210
          labrador-guy
            I should have known better!   Another near miracle right here on the AOMCI web pages!  Thanks for sharing.
            dale
            #285225
              Not hardly a miracle.
              There were a few thing that needed fixing
              but it was mostly just cleaning.
              Most everyone on here could have done it.
              #285253
              David Bartlett
                I have to make an inner muffler tube. Does anyone have a picture of one, or an idea of how many holes are in the inner piece and the size of the holes?
                Thanks again!
                David Bartlett
                #285254
                stanley
                  David Bartlett
                    http://www.oddjobmotors.net/tt3_johnsonainnermuffler.htm
                    That is way easier than what I had in mind!
                    Thanks!
                    David Bartlett
                    #285278
                    stanley
                      Only thing I would add is to make sure all carbon is scraped out of grooves that muffler and wrap fit in.Also it’s easiest to fully assemble with manifolds before putting on powerhead.I’ve done lot of them including making the outer wrap and do them this way
                      #285349
                      David Bartlett
                        I started working on the external muffler can. Got the paint off and started working out some small dents.
                        Still have a ways to go!
                        David Bartlett
