Home › Forum › Ask A Member › 1928 Johnson A-35 questions
Viewing 10 posts - 31 through 40 (of 68 total)
  • #285598
    David Bartlett
      I made some progress on the muffler. Got some copper for the inside tube. Notice the holes are not in a straight line. That is for greater high speed performance!
      David Bartlett
      #285602
      David Bartlett
        Another photo of the rest of the motor in pieces.
        David Bartlett
        #285613
          That’s cheating!!!!!
          #285616
          David Bartlett
            Tubs,
            I will take any advantage I can get.
            On a different note, the tank has some body filler on it after stripping the paint. A couple areas are pretty decent dents, so I am going to leave it for now and put a better paint job on it in hopes that someday I may find a better tank, or get properly motivated to fix this one.( I need more practice at dent removal)
            David Bartlett
            #285822
            David Bartlett
              Tonight I put the crankcase back together and put the newly painted cylinders over the pistons…….TWICE!
              I had the wrong piston in the wrong hole and things wouldn’t go all the way around. At least I discovered my error before I went any further!
              David Bartlett
              #285834
              T….in Wisconsin
                It’s looking really nice Dave.
                Did you paint the jugs or just clean them up? They look good.
                I just picked up a A-35 parts motor. I haven’t even tested the coil yet.
                T.. in Wisconsin
                #285835
                T….in Wisconsin
                  I just saw your posting on painting the cylinders.
                  #285836
                  T….in Wisconsin
                    Dave, I may have a tank for you.
                    I’ll post a few pics tomorrow.
                    T.. in Wisconsin.
                    #285842
                    David Bartlett
                      Thanks Tim! I would love to see it.
                      David Bartlett
                      #285844
                      David Bartlett
                        The cylinders did look good with just some paint stripper and a wire brush. I almost left them as is, but chose to paint.
                        David Bartlett
