Home Forum Ask A Member 1929 Johnson Model J-25 Plug Wire
  • #259401
      I can take a pump apart an to get you piston
      dimensions if you are planning to make a new one.
      A "Boat House Repair" is one that done without having tools or the skills to do it properly.
      #259402
        Thanks Tubs, I’ll clean it up today and see what the diameter of
        the piston is, and perhaps estimate how much of the length is
        missing, and if I need more info., I’ll let you know.
        The real question is, “what” I’m going to find to make a new piston?
        I presume that I’d need to silver solder some “hard facing” of some kind, on the
        end that rides on the cam.
          I don’t think there was a hard facing on the piston.
          The piston is sacrificed to persevere the cam on
          the prop shaft gear.
          #259406
          davidk
            Also consider the surface of the cam.  No sense in rebuilding the piston if a corroded cam will just chew it away.  See this discussion https://www.aomci.org/forums/topic/early-johnson-plunger-for-pump/
            #259407
              Thanks for the replies. Regarding “hard surfacing”, maybe I was thinking about
              the photo I seen once of someone soldering a nickel onto the piston!
              I decided to reuse the piston, as it was just the one end buggered up.
              I made a stepped brass end where about 1/8″ inch presses into (and soldered)
              the good end of the piston, and another 1/8″ sticks out beyond the end of the
              piston, that rides on the cam.
              That’s all the longer I could make brass end, and still have clearance without
              bottoming out. I suppose one could shorten the piston in order to have a thicker
              brass “wear end”, but this should last quite a while, and forever, if I don’t get
              it running!
              My real thought of the day, how long was this motor ran with that big hole
              in the water pump piston? I can’t see how it possibly pumped any water?
              Photos this evening, I hope.
                • This reply was modified 2 years, 8 months ago by Tubs.
