Home Forum Ask A Member 1946 Flambeau
  • #273662
    JIM PAIGE
      Can anyone tell me the butterfly position in the  carburetor of a 1946 Flambeau outboard?  And also what is its function?
      #273664
        I’m not sure if you’re talking about a “certain” position to synchronize the
        carb butterfly / throttle plate with the magneto, or elsewise.
        I have to think it’s purpose is just like any other engine to that uses throttle
        plates in the fuel system, to regulate air flow through the carb, and hence
        atmospheric pressure and fuel delivery.
        #273686
        JIM PAIGE
          If I could see a picture of how the spring is set and the throttle plate before closing it up, that would be a great help.   Someone had the motor appart and now I’m not sure what’s right.
          #273691
            These are the only carb photos I have of my 5 hp Flambeau.
            DSCN8950
            DSCN8952
            DSCN8962
            DSCN8965
            #273776
            JIM PAIGE
              This is an early model 1946 it doesn’t have anything to control it on the outside and nothing to keep the spring from coming back.
              #273806
              JIM PAIGE
                1. Here are pictures of my problem
                #273808
                JIM PAIGE
                    At one time, there must have been a lever, or gear like mine,
                    attached to your broken throttle shaft.
                    Regarding the spring, it’s probably bent, or the end broken off.
                    One end is in a hole in the throttle shaft, and the other end
                    must have hooked on the carb body some how.
                    Hopefully someone will come along with better photos or knowledge.
                    Keep an eye out on Ebay for Flambea parts or photos of carbs.
                    #274055
                    JIM PAIGE
                      Dumb me, I went and looked at the cover I had primed and there it was a manual working lever for the butterfly! You push it in and turn, I should have remembered that when I took it apart.
                      #274056
                        Not to worry, I have a “dumb me” realization on every project!
