Home › Forum › Ask A Member › 1948 Johnson
- This topic has 8 replies, 6 voices, and was last updated 9 years, 9 months ago by
mr-asa.
April 30, 2015 at 11:18 pm #1380
I bought a 48 5hp Johnson and used 3 years. Runs great. I think 48 – first year "twist throttle" avail. F/N/R lever broke inside. Shift and nothing happens. Parts rattle inside. Handy with engines, not outboards. Will tackle in a week or so. Will I be able to logically see what’s wrong, and do you think I’ll be able to find parts? Where?
April 30, 2015 at 11:55 pm #15151It’s may be a 1954, if you take off the power head you should see the problem. Doug Penn on the internet would be a good place for parts.
May 4, 2015 at 2:05 pm #15317OK I’ll tackle it. I found Doug Penn on line for when I need parts. Thanks for the help.
May 25, 2015 at 10:29 pm #16862Found problem. Did as advised. Tip broke off top of shaft that runs down to foot so it’s not connected to upper shift lever. Before I contact Doug Penn and get the part, is it going to be as easy at the bottom end? I know I need to take lower foot off to get loose part out of there. Do I need special tools or will I be able to "see and figure out" like I did with the top end? Thanks for your comments – I’m having fun. Last thing it’s a CD-12
May 26, 2015 at 1:22 am #16892JANMOL
Welcome to the forum.
It is a1955 Johnson. Great motor, I have one for a fishing motor.
Sorry but the lower unit will not be as easy as the top.
I’ll let someone else explain what Your going to have to do,
I’m not that good at it.
Here is a link to a parts breakdown at marinengine.com for it.
http://www.marineengine.com/parts/vinta … 700001.htmGood Luck with it.
Steve A W
Member of the MOB chapter.
I live in Northwest IndianaMay 27, 2015 at 2:31 am #16997Thanks for all the help. Found part number, but not available. I’m trying to find an entire lower unit. If not, I’ll figure out a way to fix it at the top end with hardware I find somewhere. It’s become a mission. I can’t seem to let this thing die. I’m flabbergasted at the engineering and workmanship in this thing. It’s maybe almost too complex, but a thing of beauty. I’d forgotten how spectacular workmanship was on products of that era. 60 years old and I can keep it running! I see how you guys got addicted to it. I may also someday, but for now I just want to take my grandson fishing in an old 12′ boat I found on some property I bought and made seaworthy again.
May 27, 2015 at 2:42 am #16999Your motor is far from dead. The good thing is parts are around and not too expensive. You will have to get a used one, but that’s ok. These are among the best running motors and can hold up to any new motor as far as function.
May 27, 2015 at 2:39 pm #17021What, exactly, is broken on your motor? I have a fair bit of parts and pieces in my bin from 1950s Johnrudes and may have what you need…
May 27, 2015 at 2:54 pm #17022quote Chinewalker:What, exactly, is broken on your motor? I have a fair bit of parts and pieces in my bin from 1950s Johnrudes and may have what you need…It sounds like the broken part is the shift rod, #43
Is that correct JANMOL?
