Home › Forum › Ask A Member › 1949 wizard 6 hp
  • #182220
    GARY STEFFENEY
      looking at replacing waterpump impeller,, have taken off spring clip now how does plate come off is it screwed on or just pull off,, thank you for any info,,,,
      #182258
      melugin
        When new, the plate would fall out. Now, it may take considerable persuasion. With plenty of WD-40 and gentle prying with a small screwdriver tip at the alignment slot, I have managed to loosen several.
        #182281
        GARY STEFFENEY
          thank you,,,, I will keep you informed on progress,,,
          #182303
          mercguy
            I often need to use this process: I remove the entire pump and shaft unit by removing the 2 screws. Then with no drive pin thru the shaft, I slide the shaft back so I can insert a pin thru the impeller driver and the outer hole of the shaft. Then tap on the shaft as a puller to remove the cover.
            #182549
            ROBERT LAFAYETTE
              4172896373_2366660539_b
              #182905
              GARY STEFFENEY
                thank you for help and diagram,, I did get it apart and impeller was reallyi bad, I ordered one but not correct I need one with two knotches for drive collar,, where do I look for this type,, and thank your for assistance,,,,,,
                #183027
                ROBERT LAFAYETTE
                  Give Joe a call at Ferguson Poole.
                  http://fergusonpoolemarine.com/enginecoolingsystem.html
                  #183174
                  Ron Devries
                    Old Mercs might have one too.
