Home › Forum › Ask A Member › 1957 Johnson 5 1/2
- This topic has 20 replies, 7 voices, and was last updated 7 years, 1 month ago by
goldmember.
February 7, 2019 at 9:09 am #166235
I’ve had the same problem with certain websites. If you were trying to direct him to the online service manual, I uploaded one and a condensed version good to download for a week at this link – https://we.tl/t-lrHeUotPNM
This reply was modified 7 years, 1 month ago by
Steve D.
February 7, 2019 at 10:09 am #166237i tried sending links to utubes and the boat info johnson bible (red book) all my replies went poof !
thanks I had the condensed version
February 7, 2019 at 10:35 am #166241Thanks Guys. Something is seized up but I dont know if it’s the lower unit or the powerhead. I pulled the plugs and looked at the cylinder and pistons (what I could see) and it looked brand new. The whole motor is in great shape, I am surprised I cant get it moving.
I am going to pull the powerhead and determine if its that or the lower unit. Stay Tuned!!It’s such a great looking motor I really want to get this figured out.
February 7, 2019 at 4:42 pm #166273https://www.youtube.com/watch?v=SVOedhzPP7M
February 7, 2019 at 5:39 pm #166280Have you drained the gearcase? Perhaps the gearcase is seized up, or the driveshaft shock spring has sprung binding up the gearcase….
February 9, 2019 at 8:36 pm #166477Not sure how to do that or how to investigate “driveshaft shock spring”. Guess I’ll have to read up.
February 9, 2019 at 11:25 pm #166485go to boatinfo.no site
click on the book stack
drill down to JOHNSON
and select the big red book ….http://www.boatinfo.no/lib/johnson/manuals/1922-1964johnson.html#/420
February 9, 2019 at 11:27 pm #166486I cant post the boatinfo.no site my replies go poof
but go to the site select the book stack on top
then johnson… go find the red book open it go to the lower unit section flip the pages and you will find info
February 9, 2019 at 11:29 pm #166487find the boatinfo site all there my replies still go poof if I post the link
then Jonson then red book … go to the lower unit section for info
February 10, 2019 at 1:20 am #166493That has a Nylon starter paul that may break. It is common for the clutch below the water pump to expand and cause the drive shaft to lock up. I don’t have the Johnson parts book but most Evinrude Fisherman / Fleetwin parts are interchangeable. I hope this helps . . .
garry-in-michigan.
