Home › Forum › Ask A Member › 1959 fisherman 5.5 help
- This topic has 67 replies, 13 voices, and was last updated 7 years, 3 months ago by
JACQUES.
May 3, 2019 at 9:52 pm #174798
Those digital meters can be confusing and misleading, especially if you don’t have them set correctly. When you say “no reading”, I am assuming you mean infinite ohms or an open circuit. I am assuming that the green wire is the coil primary lead and the black wire is the coil ground, common to the primary and secondary leads. The proper way to test the secondary circuit is to touch one lead to the coil ground lead, the other lead to the plug terminal, this should show several thousand ohms. Touching one lead to the coil ground lead, the other lead to the coil primary should show about 1 ohm. Needless to say, your meter must be set properly or you will misinterpret the results. You may want to try testing the other coil first and compare the results before buying a new coil. Keep in mind, that even a coil that reads correctly on an ohm meter may be defective, especially if the secondary has an external leak/crack allowing arcing to ground.
May 3, 2019 at 11:28 pm #174800meter reads zero no ohms i did the same on other one and that did read .8 then nothing kinda weird.i tried it in all modes and same out come.so dont know what is right but i ordered a new coil..only thing else it could be is fualty piont for some reason but they look great and are clean.
May 4, 2019 at 12:11 am #1748011- touching your probes together will give you your 0 ohms referrence (max conductivity since the probes are touching themselves. IF using a needle meter touch the probes and …adjust the needle to 0 ohms to establish a referrence of 0 ohms on the scale being used .Always reset the needle to 0 when changing to a diff. scale.
Make certain the meter’s inside battery is fresh……..(they all have a battery inside) !!!!
2- that said probing the green and black will give you your primary winding resistance 1-3 ohms max not much more (if using a needle meter use 100 ohms scale or lowest possible scale above the expected 3 ohms reading
3- that said ….. black to HV pin probing gives you the secondary winding at 4-7 kohms … if using a needle meter set the scale to 10 kohms !!
if your digital meter shows nothing (no value) similar to when the probes did not touch themselves before starting step 1 above …. you have infinity … open …. infinite resistance (air) which is an open secondary winding
https://www.electronics-notes.com/articles/test-methods/meters/multimeter-resistance-measurement.php
May 4, 2019 at 4:38 pm #174820http://www.pochefamily.org/outboard/Coils.htm
better late than never …
May 5, 2019 at 7:51 am #174833I am assuming you were checking the primary circuit during you restest, correct? .8ohms seems correct, zero ohms means the primary is completely shorted….That being said, those digital meters are very hard to read, and not all that accurate when reading super low resistance readings (below one ohm). The readings seem to jump around and add to confusion. I admit to being “old school”, and love my simple Stevens AT 101 analog meter….Like anything else, I’m sure there are some digital meters that do a great job in the low ohm range, but the jumpy readings sure can be confusing….
OK, so you have ordered a new coil. If the new coil doesn’t solve the problem, then I would swap the points to see if the problem swaps cylinders….If not, I would swap the condensers. Bad condesners are often overlooked, and they do deteriorate with age. And, just because they are new, doesn’t mean they are good. I am trying to remember if you replaced the points and condensers, am assuming you did…If so, did you use an OMC ignition kit?May 10, 2019 at 2:54 pm #175045ok so got new coil on and went through points again…still losing spark at about half throttle but was messing around with it because it weird that it doing this..so at half throttle i lose spark but when i push down a lil bit on the mag plate where the piece sticks out to move the throttle the spark comes back and is fine..i am lost now any one have this problem…i did put very lil grease on the bottom of mag plate when i resembled it where it makes contact with mounting plate for it and the inside of mag plate should i have not done that.
May 10, 2019 at 4:44 pm #175046You did right in lightly greasing the mag plate. Low voltage does not cross that junction, only high (spark) voltage which has no problem getting past the thin smear of grease.
May 10, 2019 at 5:04 pm #175047try adding a piece of wire linking mag plate surface to engine surface this will ensure electrical conductivity between sparkplug bodies and the ultimate return path to the high voltage coil winding (the secondaty winding)
when you push down on the mag plate you are probably closing the path
mesh shielding from a piece of TV coax cable makes a nice flexible conductor
just for a test … with that new coil
you should now read a good 4-7 kohms on the secondary at the plug boot when measured to the engine main body
if not find out why !! press down on the mag plate to see if 4-7kohms suddenly appears
both secondaries should have solid 4-7 kohms
This reply was modified 7 years, 4 months ago by
JACQUES.
May 10, 2019 at 6:29 pm #175051Pressing down on the mag plate changes the breaker point gap and clearance between the coils and magnets. This could be significant if it is worn really sloppy. However, they all have some wiggle.
May 10, 2019 at 7:25 pm #175053well if the ground wire does not help we will know it is more mechanical than electrical
hoping to see ohms readings and wiggling impact on measurements.
when we find cure for this oldy I am certain we will be amazed
