Home › Forum › Ask A Member › 1959 Johnson 3hp
  • #6132
    John
      I am thinking of adding a ’59 Sea Horse 3hp to my collection.
      from what I see on the interweb, it is a JW-15 ??
      I would be interested in seeing some photos of it if anyone has any.
      also to know the length and weight of this motor.
      #51263
      kerry
        Weight is 33 lbs. From the ’59 brocure http://www.boatinfo.no/lib/evinrude/bro … 1.html#/10
        #51267
        CHUCK
          John
            awesome !! thanks guys !!
            but – isn’t it a little pretentious to state: "It has Angle-Matic Drive that lets you
            drive right through shallows, over the stumps and logs without a care … Through
            water that will defeat any other outboard" ???
            does it jump over tall buildings and faster than a speeding bullet ??
            good salesmanhship is all in the talk.
            Anyways – I LIKE IT !! I will start looking for one to use as an auxillary kicker.
            Thanks again !
            #51271
            David Stanton
              It will bounce up when hitting things, and it’s not moving as fast, with as much force as bigger HP motors, but, yes, you still can damage them, especially with rocks. Logs are more forgiving. That being said, at trolling speed, these will take an amazing amount of abuse, but, if you plan on using it that way, I recommend you take a lot of brass shear pins along.
              bkrsdoz
                Certainly one of the best fishing motors OMC ever made!
                #51279
                  The weak point in the OMC three horse motors thru ’63 was in the exhaust tube right below the swivel clamps. They liked to snap off in this area quite easily. The ’64 and later models were beefed up with a different clamp design and exhaust tube.
                  outboard315
                    I have 3 evinrude lightwins and they run like a top and are great little motors.
                    #51289
                      quote Mumbles:
                      Really? Gee, you must have all the bad luck. I’ve never seen a broken one. At least it has two clampscrews.
                      #51306
                        Johnny
                        Another weak point is the carry handle. Try to get a motor that
                        has a good handle. Their hard to find.
                        Steve A W
