Home Forum Ask A Member 1959 Johnson 3hp
  • #51309
      quote FrankR:
      Really? Gee, you must have all the bad luck. I’ve never seen a broken one. At least it has two clampscrews.
      No bad luck here. Only good luck as I had a ’59 Lightwin given to me which was broken off in the area indicated. The PO had it mounted as a kicker on his boat and while navigating with the main motor, he bumped the wharf with it breaking it off. Since he had no use for a broken motor, I jumped on it when he offered it to me as I had the parts needed to fix it. It runs great now and someone had already installed new coils in it. That’s what I call good luck!
      #51318
        Ah-ha, the rest of the story, as they say. Just a light "bump" against a wharf and it broke. Durn puny little motor.
        #51334
        bkrsdoz
          I collect them.
          I have ’52 through ’59 and a ’67 sailboat high thrust, and a ’67 folder.
          They are great motors.
          #51348
          johnny-infl
            that’s not collecting – that’s HOARDING !! There should be a law.
            #51362
            outboard315
              quote bkrsdoz:
              I collect them.
              Well I see 2 KG7’s is there another 7 off screen?
              #51397
              bkrsdoz
                1 KG-7 & 1 KH-7
