Home › Forum › Ask A Member › 1973 6Hp Evinrude Fisherman hard starting cold
- This topic has 75 replies, 9 voices, and was last updated 2 years, 6 months ago by fleetwin.
May 7, 2022 at 2:44 pm #259529
you can probably buy a motor /mag plate for the same price !!!
May 7, 2022 at 2:59 pm #259534Just out of curiosity- All those older OMC mags 1960 through about 1975, 3 to about 20 hp look very much alike- almost identical in fact. Are they interchangeable? It would make it easier to find a substitute.
May 7, 2022 at 4:27 pm #259536I know I have a few 6hp mag plates, although they don’t include coils. Let me know if you want one, just pay for the shipping. Don
May 7, 2022 at 4:42 pm #259537Do you know if the mag plates are “common” to all the small hp OMC’s. If they are I could likely source one from around the neighbourhood. If not, I would take you up on your kind offer If you are confident they are not too worn, I don’t need coils as the ones I have are almost new. Where are you and how much do you think shipping might be to Sudbury, Ontario, Canada?
May 7, 2022 at 5:04 pm #259538Further curiosity- does anyone out there know what the diameter of the crank case bearing surface at the mag plate should be, or how I could measure it’s wear?
May 7, 2022 at 11:51 pm #259546I found an old post by one of your guys called Mumbles “February 26, 2019 at 3:58 pm#169760
The universal mag was used on the 3 and 4 horse motors until ’84, the 6 until ’76, 9.5, 18, and 40 horse until ’73, 20 and 25 horse until ’72. The 2 horse used it until ’86 and the 1.25 and 2.5 horse motors used it from ’87 on.Remember the cranky Low Tension mag as used on ’74 – ’76 9.9/15 horse motors? It and the Universal Mag were replaced with the superior CD (Capacitor Discharge) Ignition system as time went on.
This gives me the impression that any mag plate from any of the 3-25 hp OMC’s from about 1960 -75 would fit. I’ve got a scrap power head from a 1960 18 hp Johnson that I could swap. Any comments?
May 8, 2022 at 12:12 am #259548if you look up the parts listing both the 6hp and 18 use mag plate # 0584810 so they are identical 🙂
Evinrude Parts & Johnson Outboard Parts at MarineEngine.com
May 8, 2022 at 12:15 am #259549Thanks – I never thought of that. I’ll dig out the old 18 hp powerhead.
May 8, 2022 at 9:49 am #259568btw thay also show an original part# 0580360…..but the 0584810 is a replacement/equivalent
so basically whatever the part # you have the 18hp mag should swap
May 8, 2022 at 12:40 pm #259579The mag plates themselves are all basically the same from the mid fifties until their demise. Hence the name ‘Universal Mag’. The only difference in any of them may be the position of threaded holes for clamps or cams etc. Any replacement should have the boss cast in which can be drilled and threaded for the necessary hardware.
