Home Forum Ask A Member 1976 merc 110
  • #1083
    billy-t
      Thinking about changing the impeller on my friends 9.8, haven’t done that much work on a merc.
      how tough a project is this going to be, do i need any special tools?
      Thanks
      Billy T
      #13176
      jasonh
        No special tools. There was a goofy thing with driveshaft diameter to be cognizant of. There were 2 different size impeller hubs. You may have to measure old one before buying impeller.
        #13192
        Doug Wilson
          US Member - 2 Years
          take the front and rear bolts lose and lower unit should slide down may need to bump it down some before it will drop .Make sure when going back together that it is in the same gear it was when you took it out. I usually put a small dab of antisieze compound on the splines on the shift shaft and drive shaft helps it come apart easier the next time
          Doug
          turned off?
          #13194
          mr-asa
            Trickiest part for me was always sliding the lower unit home when I was done. Lining up the driveshaft, shift rod, and coolant line can be a bit of a bear. Can help to turn the motor upside down so you can see whrre it is all going.
            #13233
            Doug Wilson
              US Member - 2 Years
              I have never turned one upside down but have a used various tools to guide the line into the water pump.
              Doug
              turned off?
              #13236
              mr-asa
                I never have done so either, but it was posted on here before the board crash and I saw the wisdom in doing it that way.
                #13253
                wedgie
                  Turning it upside down helps a lot. 😉
                  #13287
                  billy-t
                    Thanks fellows much appreciated
                    #16066
                    billy-t
                      Okay so thinking about getting started , on the diagrams what do i take out to have the lower unit drop?
                      #16067
                      billy-t
