Home Forum Ask A Member 1978 Johnson 2 hp
  • #11316
    rickinfarmington
      Have a 2 hp Johnson that I just can not get to idle. It has 90 psi compression, runs well at half to full throttle. Ran it on a boat for a half hour at half through full throttle. Went through carb several times. Out of the test tank, it idles right down to a tick over, but in the tank it dies.
      #83410
      shane-r13
        90 is a bit low for these. They like over 100 psi generally. Hows your head gasket? I have the same issue with my ’75. It has 105 psi, new carb kit, new head gasket, new ignition and still wont idle right down in tank or on boat. I personally think mine maybe the lowing bearing seal maybe toast, could possibly be the same issue for you?
        #83412
        rickinfarmington
          I do know one thing and that is I am spending way too much time on this engine. Have heard a number of members saying these little motors never did idle worth a darn.
          #83430
          lloyd
            I have both an Evinrude and Johnson version of that motor that ran and idled well. They need about 120 psi to run well as I recall.
            #83431
            reivertom
              I think they must be hit or miss on these little buggers.. I have one with around 95 psi that idles just fine. I didn’t expect it to run as well as it does when I ran a compression check.. I don’t know why, but I am just happy it does. I never expected it to idle like a 3hp twin. I think the old twins just spoiled everybody..
              #83447
              donsmarine
                tank to small, try it with the prop off in tank. tank not allowing enough fresh air.to much water in tank,motor to deep in water. just guessing.
                #83457
                  If you are using a compression gauge with a checkvalve at the gauge end of the hose, you have higher compression then you are reading because the volume of space in the hose is significant and will lower the reading with that little cylinder. I have one of these 2 HP Johnsons and it idles great
                    In my book the best single they ever built was the 1948 through 1951 Sportsman., , , 😎
                    #83474
                    rickinfarmington
                      OK, So I just pulled the prop off and the little engine runs at tick over speed, in the tank. Perhaps I could chase down a lower pitch prop to make up for a possible low compression. Will also look into re-ringing it.
                      Just for grins, I may try running a heavy weight oil in the mix, with the theory that it will help with the compression.
                      #83527
                        Well…It’s kind of an all on nothing deal for these little engines….Either they idle pretty darn nice, or they won’t idle at all regardless of the normal carb/ignition repairs…
                        90PSI may be low for compression, but as others have said, the small combustion chamber tends to create inaccurate compression gage readings…
                        When was the last time this thing ran/idled OK? Has it been sitting for a long time since it last ran/idled OK? Did you lend it out, has it been overheated?
                        Generally speaking, when these things are "worn out", they are hard starting, won’t idle, and are low on WOT power. But, on the other hand, I don’t want to condemn this powerhead just because it won’t idle right…There may be a fuel/ignition problem.
                        I guess I would try a different compression gage first…The long hose on many testers can be enough to lower the compression readings. If you confirm the 90 PSI readings as accurate, you may want to pull off the head and exhaust cover (provided this is not a salt water engine) to have a look at the piston skirt/rings/cylinder wall. Trying to find a lower pitch prop to solve this issue is probably not going to work out, there is no smaller pitch prop available. But, on the other hand, be sure no one has substituted a larger pitch prop for a 3-4hp engine, which may indeed be overloading the engine….
                        Generally speaking, trying to "rering" these engines is not an effective repair, the piston skirts/cylinder walls are usually out of round requiring boring the cylinder oversize along with oversize piston and rings. I don’t recommend doing this major rebuild on this little powerhead.
                        The lower bearing/seal could indeed be leaking causing a crankcase leak, but this would not explain the lower compression reading….
