Home › Forum › Ask A Member › 1st time Painting/Decal Questions
- This topic has 13 replies, 6 voices, and was last updated 4 years ago by
bob-d.
September 18, 2022 at 6:56 pm #266293
Lovely job Mumbles. It looks just like new, without a too glossy finish, just as they were back in those days
September 18, 2022 at 8:08 pm #266294The complete motor was stripped down to every nut and bolt for rebuilding and all of the painted surfaces were glass beaded and smoothed using Bondo and elbow grease. Paint used was a DuPont automotive base/clear system and was sprayed using a touch up gun instead of a full size gun. This CD only got one or two light coats of clear instead of the usual three as I remember I was running out of material that day. It must of been cloudy the day the photo was taken as the motor does have a shine to it. And the shine it does have is without wet sanding and polishing the clear. The clear went on wet and didn’t have any sags so once it kicked off from the activator added to it, I just left it.
The other motor is my Mish Mash motor, assembled from extra ’54 – ’58 J/E/Elto parts laying around the shop. The powerhead got fully rebuilt just like the others but I decided to leave the exterior au naturel. The bare aluminum on the back of the block just above the head is from when it was resurfaced on the lathe. The cylinder head would have gotten the same treatment. It ran good in the barrel the last time I used it but it really deserves to go for a lake run sometime.
September 19, 2022 at 2:40 pm #266335Bob, Still a little confused, I posted again.
I spray painted on the primer with a spray can. Sand the primer now before painting ? If so , what grit ?
How should I sand the lower unit, etc. and with what grit ? Just 120 grit and then prime ?
September 20, 2022 at 10:39 am #266374Rick, 120 in fine for your first pass at the lower unit. When it nice and smooth, prime and then sand again with a 320 or 400. When it looks and feels good (you can pick up a lot of imperfections by hand feel) put on your last coat of primer and then topcoat.
Another good painting tip in order to get sharp paint lines between colors on the cowl is to use 3M fine line tape. It’s a 1/4” tape that goes great around curves, and gives a much better paint line.Bob D
