Home Forum Ask A Member 2000 Johnson 50hp 2 stroke questions.
Viewing 4 posts - 21 through 24 (of 24 total)
  • #186198
      US Member - 2 Years
      You are so right buddy, simpler is usually better….I don’t want to say that these don’t idle as well as the old ones, they do….It is just more of a project to get them there…And, you are right, if it is idling OK, don’t mess with it….
      • This reply was modified 5 years, 4 months ago by fleetwin.
      #186201
      lindy46
        Checked compression, 148psi on both cylinders. Here’s some pics.
        #186232
        vintin
          The 50 is a looper design and loopers are known to not have the best idle. Loopers shine in other areas such as higher performance, fuel efficiency and cooler running pistons due to less piston mass exposed in the combustion. Hydraulic tilt/trim and availability of stainless steel propellers is nice, too. I went looper a few years ago and will not be going back.
          1958 Feathercraft Vagabond, short shaft 1998 50hp Johnson:
          • This reply was modified 5 years, 4 months ago by vintin.
          #186267
            US Member - 2 Years
            Motor looks to be a low hour fresh water engine, good for you!
