Home Forum Ask A Member 2953 evinrude 15hp
Viewing 7 posts - 21 through 27 (of 27 total)
  • #286051
    Jack Strobel
      Steve, they sent me # 11???
      Jack Strobel
      John is my sir name and was on my card when I signed up!
      #286052
      joecb
        John,  it sounds like you are well on the road to success with that motor. On line help is good but in-person help is better… where are you located? Have you hooked- up with a local chapter? attend a local chapter meet / swap and sell… lots of help and parts
        Joe B
        #286062
        Steve D
          If that larger o-ring actually is #11 it can’t be accessed anyway unless the block is apart. At least they sent you a correct one for the job you’re doing now.
          #286127
          Jack Strobel
            Joe, thanks – I have been contacted by Mike Glen from my local area and he gave me some names and #s
            Steve, that carbon seal scares me? What would be a safe way to tap it in? Do the 2 recesses go down? Should I lube it (saw perm aviation sealant on you tube)
            thanks
            Jack Strobel
            #286129
            labrador-guy
              John, you don’t tap the carbon seal into anything!
              thanks
              The spring under the point cam presses it to the edge of the top bearing.  The “O” ring spins with the crankshaft and the carbon seal.  Look it over close you will see how it is supposed to work.
              dale
              #286130
              Steve D
                “What would be a safe way to tap it in? Do the 2 recesses go down? Should I lube it (saw perm aviation sealant on you tube)”
                No sealant required anywhere for this, notches up, machined side down, lightly lube I.D. of o-ring to help fit over crank, don’t tap as Dale said, some guys use a piece of pvc exact size as carbon seal so even pressure is applied all the way around to avoid breakage, then gently push down.
                #286171
                Jack Strobel
                  Thanks, good stuff
                  Jack Strobel
