Home › Forum › Ask A Member › 3 hp Evinrude question (’50s to 60s)
- This topic has 44 replies, 17 voices, and was last updated 4 years, 8 months ago by
crosbyman.
July 27, 2020 at 10:29 am #210038
I thought I had run out of questions, but here’s another: which gas should I use? plain 87 octane or a premium? Some of the premiums don’t have ethanol.
July 27, 2020 at 10:44 am #210039Here’s a link to a site that lists ethanol free gas.
Member of the MOB chapter.
I live in Northwest IndianaJuly 27, 2020 at 12:29 pm #210046I thought I had run out of questions, but here’s another: which gas should I use? plain 87 octane or a premium? Some of the premiums don’t have ethanol.
I use regular pump gas. These are low compression engines and work fine on 87 octane. Just use any leftover gas in your car or lawn mower at the end of the season.
David Bartlett
Pine Tree Boating Club Chapter"I don't fully understand everything I know!"
July 27, 2020 at 2:22 pm #210055OK. I changed the oil on the bottom unit and put just a little gas into the tank. (This is a motor that came to me empty.) Can’t get it to start or even sputter. What’s my next step?
July 27, 2020 at 3:08 pm #210057Check for spark, then pull the plugs and check for fuel, either flooding or dry.
July 27, 2020 at 5:44 pm #210065I thought I had run out of questions, but here’s another: which gas should I use? plain 87 octane or a premium? Some of the premiums don’t have ethanol.
Believe it or not, these engines will not run well on high octane fuel, don’t ask me how I know…. Like David says, these carbs aren’t affected much by the ethanol, so I wouldn’t worry about it, 87 octane is just fine. Be sure to drain the tank and carb completely at the end of the season though….
July 27, 2020 at 6:26 pm #210072Dumb question: How do I check for a spark?
July 28, 2020 at 6:41 am #210120A "Boathouse Repair" is one that done without having tools or the skills to do it properly.
This reply was modified 4 years, 2 months ago by
Tubs.
July 28, 2020 at 7:57 am #210124Dumb question: How do I check for a spark?
Theoretically, these engines should produce spark powerful enough to jump a 1/4″ air gap while cranking. But, I’m sure you don’t have an actual “spark tester”. So, I would remove the plugs, ground them externally, then crank the engine. It might be easier to have an assistant crank while you watch, and do this in the shade/dusk/dawn, so you can see the spark jump the gaps.
Please be careful, make sure there is not spilled fuel around on the engine and that the engine isn’t spitting fuel out of the cylinders…Perhaps you might want to leave an old set of plugs in the block while you watch a new set of J6Cs spark while grounded to the block…
You may want to consider removing the starter, then removing the round inspection cover on top of the flywheel if so equipped… This is a quick and easy way to look at the coils to see if they are cracked/split while sneaking a peak at the points to make sure they are not oil fouled.July 28, 2020 at 11:46 am #210150Did I mention that I got two? The second one was cheap–$60–and I figured if I can’t get one going maybe I can succeed with the other. I replaced the fuel line on this one–it was leaking. I got it running but it wouldn’t stay running.
