Home Forum Ask A Member 30 hp javelin
  • #167895
    Tinman
      Just picked up a 56 javelin. My boat is a 1752 flat bottom Jon. Weight about 660 empty. If I put this motor on there what can I expect performance wise? The boat is rated for a 50 hp. Thanks!
      #167942
      Steve A W
        US Member - 2 Years
        Ought to be fun!
        Member of the MOB chapter.
        I live in Northwest Indiana
        #167947
        Tinman
          I hope so! I had a 2000 25 hp and it would barely plane it. Was looking for a 35 hp but this motor just fell into my lap!
          #167970
          labrador-guy
            US Member - 2 Years
            Gotta have the right prop for your outfit! Your 660 pound boat with 200lbs of people a gas can and life jacket, real quick you will be pushing 1000lbs. My 53 twenty five erude pushes my 14footer about 26/27mph. That Javelin might make it to thirty or so, with the right propeller. Plenty of members looking for one of those fancy Johnsons, if you have the mind to sell it. Sound like fun for sure!
            dale
            #167971
              Put a tac on it and check rpm at wot with your normal full load in the boat. Then change your prop so motor reaches max rated rpm at wot with that same load. Do not over prop that motor, it will not live long if you do.
              #168025
              auldscott
                US Member - 2 Years
                Think you are going to have fun with the Javelin! Gotta wonder, though, why your 2000 25 hp would barely plane your boat. I had a 2000 25 hp Johnson on my Lund SSV-18 (dry weight 460) and it would run 26 mph with one aboard, 23 mph with four.
                #168047
                Tinman
                  It would get me about 23 mph. 2 guys 12 gallons of fuel. 2 batteries trolling motor , gear. It would plane , I just felt like it struggled. I don’t want to go crazy fast , maybe 25-30.
                  #169657
                    With that load at 23 mph, what rpm was your motor turning?
                    #169658
                    Tinman
                      Have no idea. Was just a tiller steer. No instruments. That motor is long gone anyway. I may have to invest in some kind of tach. Learning as I go!
                      #169660
                        Sounds like your old motor (25hp) had a prop with too much pitch and that was keeping the rpm too low and not letting it reach it’s proper operating rpm. It would have done better if it had been able to rev up to it’s rated rpm.
