Home Forum Ask A Member 304098 OMC O-ring
  • #9283
    jerry-ahrens
      I’m working on a 57 Golden Javelin right now, and I need the O-ring that goes in the seal carrier on the lower end of the crankshaft. I show it to be a 304098. I can’t seem to find one anywhere. Anyone know the dimensions of that O-ring? Our local dealer usually has many OMC NLA parts, but no luck there either.
      #71489
        I’m pretty sure, but not positive, that the 304098 O ring has been replaced by 302540, which measures 1 X 1 1/4 X 1/8. Then there’s the later square O rings to replace the round ones.
        #71492
          Use 305098 Quad ring.
          #71494
            OMC/BRP thinks those things are gold. Pay the postage and I’ll send you one free.
            #71523
            jerry-ahrens
              Thanks for the replies guys. I did end up locating one of the O-rings finally. Frank, I think I’ll order some of the quad rings you mentioned from Mcmaster Carr.. are they the ones mentioned in the other thread titled ”O-rings do we have a chart”? Thanks!
              #71525
                I ordered 100 of them by size from mcmaster about ten years ago. Still have a lifetime supply. 1" x 1-1/4" x 1/8"
