Home Forum Ask A Member 39/41 1.5 hp Evinrude
  • #161095
    htbboats
      Sirs,
      I’m looking to see if there is a source for parts for this engine? It belongs to a friend and he’s ask me for assistance with it. I have not taken it apart yet but know the piston is stuck in the cylinder so for now I’m looking to see if what out there ?
      Numbers on the motor are: 4264. 02446
      Thanks Mark
      #161109
      lyks2tinkr
        4264 and an early serial number make it a 1939 Elto Cub.
        I would try some penatrating oil 1st. Patience is key when freeing up a stuck motor.
        You could start by separating the power head from the lower unit. The lower unit could be stuck.
        Be gentle when dealing with the magneto. The spark plug tab on the secondary of the coil is poorly mounted and can break easily.
        #161111
          Your Elto Cub was one of the lightest outboards ever built, and will not stand up to much abuse. Built to be light weight weight and inexpensive, most have broken the skeg off the lower unit. The small magneto had to be in top shape and piston skirt ware could reduce its power to only running the water pump. A few thousandths would be enough to do them in (As a percentage of piston diameter) They were good on a canoe but only good for trolling on any sized boat. You paid a little more to get the Evinrude Mate which had side covers.
          #170337
          htbboats
            As you may see it’s been some time since I’ve been to this forum! Anyway would any parts be available for this motor and where do I go for them?
            Thanks Mark
            #170342
              There are several ways to get parts.
              – You can post a “Wanted” ad for parts on the classified board here. The ad is free.
              – Search the classified ad board for parts.
              – Search E-bay and Craigslist for parts or a “parts motor”.
              https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR1.TRC0.A0.H0.X%22elto+cub%22.TRS0&_nkw=%22elto+cub%22&_sacat=0
              – Contact a place like Twin City Outboard – an outboard junkyard that has motors going back to 1906 – they will mail parts
              http://twincityoutboard.com/
              – There are some members that deal in parts for these old motors. If you post a “wanted” ad, they will likely contact you. Once you deal with them, keep their name and contact info.
              Most of these old motors need little or no parts – just a lot of TLC.
              Good Luck!
