Home Forum Ask A Member 55E Starter
  • #289675
    Steven Sipp
      I am currently restoring a 1955 55E. The starter will spin but the gear will not engage. I had the starter overhauled  however it still will not spin the gear  int the flywheel.  Any thoughts ?
      #289679
      labrador-guy
        Steve is your Bendix stuck?  The torque of the starter should shoot the bendix up into the flywheel.  Try holding the bendix with your hand and turn the big nut on the top of the starter armature.  The bendix should move up easily to engage the flywheel.  Are your mounting brackets correct?    The bendix should engage the flywheel at least a quarter of an inch.  Hope this helps.
        dale
        #289682
        seakaye12
          Is that one of the “swing starters” where the bendix does not go upwards…but swings sideways into the gear?
          #289686
          opposedtwin
            Should be if it’s a 1955 model.
            Take it to the place who overhauled it and show them it doesn’t work right.
            #289702
            labrador-guy
              On second thought, is your polarity correct?  Some electric motors will run backwards if the leads are reversed.  Bendix won’t work if the motor is spinning the wrong way.
              dale
              #289703
              labrador-guy
                Swing starter?  Sounds political!  Messed up for sure. LOL
                dale
                #289714
                seakaye12
                  Swing Starter   Mark 55e  Not mine;  image from my files
                  #289723
                  labrador-guy
                    Excuse my comments!  I am talking about a different motor.   I know nothing about a 55e Mercury.   Should have paid closer attention.
                    dale
                    #289732
                    dave-bernard
                      may have some mixed parts. mark 25 and mark 55 have some different parts in the swing parts cant remember which is which.
