Home Forum Ask A Member 6039 Evinrude Speeditwin
  • #186861
      Squier, I’ll probably put an ad on the classified. Just trying to figure out “bearings”
      this morning…….. out to the garage I go!
      Northumberland
        My lower unit only uses tapered bearings. From your post, yours is different. So speaking about the
        Here are the specs for the 05066/05185 cone/cup … https://cad.timken.com/item/tapered-roller-bearings-ts-tapered-single-/tapered-roller-bearings-ts-tapered-single-imperi-2/05066-05185
        and here is a link for the specs on all the other sizes available. … https://cad.timken.com/viewitems/tapered-roller-bearings-ts-tapered-single-/tapered-roller-bearings-ts-tapered-single-imperi-2
        The next one will let you search for all other types of Timken bearings.
        https://cad.timken.com/?_ga=2.138323504.1204381099.1573409853-130771345.1546634794
        Good luck!
        #186894
          Thanks again for your help!
          I’ve been looking at Timken CAD drawings as you suggested, etc.,
          and believe I’m making progress.
          It seems I need
          Prop Shaft-
          – tapered roller and race 05066 / 05185
          -ball bearing 6205
          Drive Shaft
          -tapered roller and race 05079 – 05185
          The only thing I can’t get to jive on my measurements are the cone widths,
          but perhaps I’m measuring wrong. The Timken specs show both cones
          .566 wide. One of mine I measure at .600, and the other .625.
          I’m going back to the garage to see if I missed something there!
          Good luck!
          David Bartlett
            Tom, Bucc, Fred!
            I have that information somewhere regarding bearing numbers for the lower unit on the SpeediTwin/SpeediFour. The problem is it is in storage and not easy to get to. The next time I go there I will get it. You might come up with the answer prior to that, so I will keep watch.
            David
            David Bartlett
            #187061
              Tom, Bucc, Fred!
              David
              David, David, David!
              I’ve ordered the bearings and races, so hopefully I got that correct.
              I was looking at an ad early this morning of the 1950 Speeditwin and Speedifour’s
              side by side. The lower units looked the same to me.
              Are the guts, i.e., prop shaft, gears, bearings, gear case cap, etc., the same as well?
              If so, that broadens the field of potential part donners for the prop shaft and gear case cap I need.
              I would be curious to know what you have for bearings on your list, but no big hurry now that
              I ordered already. Thanks.
              David Bartlett
                Tom,
                My Speeditwin and SpeediFour were late 1940’s motors and the internal parts in the lower units were the same. Something about the prop shaft was different where the prop fit on, but I am pretty sure the rest would interchange. Someone will correct me if I am remembering it incorrectly.
                David Bartlett
                #187072
                  Good to know Dave, Thanks!
