Home Forum Ask A Member 68 20hp Johnson Replacement Gears
Viewing 21 post (of 21 total)
  • #13325
    Casey Lynn
      If the teeth are gone the gears are in need of replacement. Find another gearcase.
      As far as a temp repair goes? No…it is probably better and longer lasting than OEM except for the heat treat.
      I probably have over two dozen of these repairs out in the field and havent heard of a set failing as far as coming out of gear.
