Trying to help a friend with his boat inherited boat and Johnson 25e77 25hp that looks to have almost no hours on it last year put impeller and new fluid in lower unit started right up recently tried to start it fires right up ran about 2 sec then died has no spark. Never worked with anything this new where do I start on the ignition?
Doug
turned off?
If it’s a tiller model with pull start, undo the stop button from the plug. Also, check ground for the power pack, as that can cause an issue like you described due to vibration, etc.
