Home › Forum › Ask A Member › 80’s/90’s 50hp opinions?
- This topic has 50 replies, 12 voices, and was last updated 5 years, 11 months ago by johnyrude200.
November 22, 2015 at 2:27 am #27495
Compression numbers on loop charged engines can really be tricky! Of course you can use the numbers to find a dead cylinder, but hard to prove a good cylinder. Scoring, glazing or just bottle shaped around the numerous ports will misled you as to conditions of the cylinders. Add to that pressure back rings (OMC / not sure what Merc called theirs) and it is hard to determine cylinder condition with just a compression gauge. The main symptom you run into is an engine that will idle for awhile and then fade away and die. You have to choke/prime it to get it to restart. If you catch it while it is slowing down, choking/priming will keep it going. If you pull the head you will fine the cylinder walls scored, glazed or woren at the looper ports (intake). Honing the cylinders will not fix this problem! They require boring oversize with proper honing after boring.
Dan in TN
[/ size]November 22, 2015 at 6:18 pm #27506All right, it seems I have a lead on a good ’88 50hp motor, with a model number E50BELCCS. According to my ID chart, that makes this a Belgium Derated model. So what does that mean…that it’s really a 55hp motor with a detuned fuel system?
Might be nice to have the upgrade option down the road…
November 22, 2015 at 7:02 pm #27507Not aware of any derated model from Belgium or otherwise. E would be Evinrude 50hp B? (maybe Belgium) E electric start L long shaft 20" CC ’88 model S suffic could mean a lot of things. If you look in a service manual those model numbers are deciphered for you. Other letters are explained. I don’t remember any derated symbol except maybe jet engines and they don’t spell out derated HP, just the way it is!
Dan in TN
November 22, 2015 at 7:24 pm #27512Listen to Dan! Do the compression test of course, but good/even readings are not a great indicator of internal conditions on these loop scavenged engines. Dan’s fade away idle/hard start hot is surely cause for concern about oversize cylinder bores and worn piston skirts. Needless to say, there are many other causes for this symptom, but worn internals should be strongly considered when evaluating a used engine for purchase. The only other thing I will add is that this symptom will not be very evident while running the engine on a flushette, it needs to be on the boat in the water and in gear to experience this.
November 23, 2015 at 5:21 am #27551Well, other than shining a flashlight in through the plug holes for a tiny glimpse of things, it sounds like it’s going to be a bit of a gamble to pick up one of these motors used. I don’t see sellers letting me pull the cylinder head to take a look at things. Fortunately the one I’m looking at has been used over the past couple of years and under the same ownership for awhile, and isn’t going to cost a fortune.
So if it’s a lemon, at least I won’t lose much more than my time.
November 23, 2015 at 3:25 pm #27558OK, well I guess I was unclear, sorry. The point is that the wear we are referring to would not be evident to the naked eye even if you pulled the head. I just spent 20 minutes typing an explanation and lost it, so will try again later….D
November 23, 2015 at 5:44 pm #27561Joel
Like I say, what we are referring to is just normal wear to the cylinder wall and piston skirt, we are not talking about scuffs and scoring. In other words, pulling the head would not show problems visible to the eye. These loop scavenged engines (40-50) OMCs are more prone to cylinder and piston wear because there isn’t much metal in the port area due to the crazy sized ports leaving little metal to metal contact. The smaller amount of contact means that the remaining metal will absorb more of the wear in a shorter amount of time. The conventional cross scavenged engines have smaller port and no big "windows" on the piston skirts, resulting in less wear. The cross scavenged engines are much more tolerant of wear, even scuffing/scoring, and will run/idle pretty well even with oversized cylinders and worn piston skirts. The important thing to realize is this wear on the loop scavenged engines only has to be a couple of thousandths as well, so compression readings may still be acceptable and even.
Dan’s description of the classic signs of this wear is great, fade away idle and hard hot restart.
So, don’t worry about pulling the head on the 50hp you are interested in, do the usual compression test and other inspections. I realize you will not be able to run the engine out on the water, and running it on a hose will not show idle problems. There is another good way of recognizing this problem without even running a perspective purchase, simply look at the sync settings. An idle speed/timing screw turned all the way in (advanced) with the throttle plates held slightly open at idle is a good indicator that someone is chasing a poor idle problem that may be a powerhead problem. Needless to say, there may be legitimate carb/ignition/sync problems causing the poor idle, but seeing jacked up sync settings should make you question powerhead condition. Again, you can see this without even running the engine.
So, we didn’t mean to scare you away from the 40-50hp OMCs, they are good engines, this condition is not all that common, just something to keep in mind when looking to buy used ones. As with all outboards, look for signs that the powerhead has been apart, "new rings and a hone job" isn’t going to fix it.
So, go ahead and give that 88 50hp a look, let us know what you think and post pictures and questions if you like. DNovember 23, 2015 at 6:27 pm #27563Well if there’s anything I’ve learned over the past year, is that you guys aren’t afraid of getting very detailed in problem areas, which is of great use for assessment and diagnosis, along with repair processes! Keep it coming!
I’ll report back as time moves along because I’ll hopefully be picking it up this weekend. If not, I’ll just keep searching.
I hope the friendly skies are treating you well this holiday season!
November 23, 2015 at 11:26 pm #27567Not as much a gamble if you are able to actually test the engine prior to purchase. By that I mean in the water and not on a hose. The engine should drop to and maintain a slow idle in gear at the static water line you will be running it at. If it does then you are golden.
That is probably the single best test of any two stroke engine and most certainly a Looper.November 24, 2015 at 1:16 am #27573As an alternative, & I know this is a reach, but how about a barrel, in gear, for as long as it takes for the motor to warm up and the thermostat open?
If I had a test prop Id run the hell out of one of these with a heat laser on the thermostat cover/cylinders for 5-7 mins, then throttle back and assess.
Thoughts?
