Home › Forum › Ask A Member › Update A-35 Flywheel Removal
Viewing 10 posts - 31 through 40 (of 53 total)
  • #280927
      The motor came to me that way. I took off the
      flywheel and there it was. The shrapnel was gone.
      Most likely the result of a loose flywheel.
      If in a pinch I suppose I could use it. Its a pretty
      common part as well, so I found a replacement.
      Possibly your motor had a similar experience.
      Operator noticed the flywheel was loose and
      tightened it not knowing there was damage. When
      you turn the flywheel does it run true or have a
      wobble? Another possibility is someone packed
      1 cylinder with rope and then used a 24″ braker
      bar to tighten the nut. Just speculation but
      something occurred that has this flywheel on
      tighter than it needed to be. Those of us who have
      responded offer our experience , or an opinion
      based on our experience. You then need to
      determine what seems to be the best approach in
      your situation. For me your decision the cut of the
      flywheel would be premature. I would be taking
      a regular framing (claw) hammer, checking the
      tool to see that its tight, and then smacking it as
      hard I as I could. I would repeat this till I was
      convinced it wasn’t going to work. That’s what
      I would do based on what you have posted. If I
      was there to see just what you have experienced
      or had the motor myself, my approach may be
      different. In the end the decision will be yours.
      How it turns out will be the experience you will
      be able to offer to someone in the future that is
      having this same problem.
      #280932
      T….in Wisconsin
        Good advice,
        Probably be best to put this project on hold and review all the information and options given. I appreciate all the information offered. I take full responsibility of any outcome that occurs from my chosen course of action.
        Flywheel on mine spins freely without wobble or any sign of interference. I used a cordless drill to turn the flywheel to check for spark.  Motor is what I consider to be in better shape than most other non restored motors I’ve seen. That said, some action deliberate or not has occurred for the flywheel to be this tight.
        Thanks Tubbs
        #280933
        JOSEPH BRINCAT
          Good call on the hammer, Tubs. I wonder how big of a hammer Tim is using. One has to impart sufficient energy to do the job. My go to hammer for this operation is a 2 – 1/2 pound brass hammer.  Tap – tap will not do it, nor will a fast swing with a lightweight hammer.
          #280934
            I’m guessing there’s at least ten people reading this thread
            wishing they could take a “Whack” at it…… literally!
            GARY
              Buc you are absolutely right,I’d buy a ticket and stand in line to take a turn at trying to removing that flywheel.
              #280968
              T….in Wisconsin
                Good bunch of guys you all are!
                I’m using a 2.5 lb mini sledge and I’ve struck it with what I consider a good whack, F=MA. I could take a video for analysis but I don’t think those files are accepted.
                Stop over. I’m in southern Wisconsin, a stones throw from Lake Ripley. Stomping grounds of young Ole Evinrude.
                #280969
                T….in Wisconsin
                  Attempt to attach link to a video file. Not sure this will work but here goes.
                  #280993
                    I once had a flywheel on a 1950s vintage Johnson that was stuck tighter than Fort Knox.   A couple days with the puller under big tension and striking the center bolt of the puller and it wouldn’t budge.   Figuring I had nothing to lose, I took a dead blow hammer and whacked around the outside edge of the flywheel – it popped loose after a few shots.  Don’t know if that would work for you but I might try that before cutting the flywheel apart.
                    1982 Evinrude 25hp
                    #281013
                      If I may ask why not use the three threaded holes & a harmonic balance puller? I’ve always used that method not tightening too much & tapping on the puller bolt?
                      Mercury flywheels are the hardest to remove. Hung the motor by a tree branch with a chain thru the puller & hammer on the puller bolt. I’m leary of using heat & messing up the temper in the metal. I’m not sure how it will take, just me.
                      #281539
                      JOSEPH BRINCAT
                        Where is Tim? did we ever hear if he was successful in removing the flywheel from his A 35 ? We all had a lot on mental energy invested in the project, he had a lot of physical energy invested.
