Home Forum Ask A Member Update A-35 Flywheel Removal
Viewing 3 posts - 51 through 53 (of 53 total)
  • #281879
    BenKruse
      Today the 8″ puller showed. Had applied heat in the past and, had let it set in penetrating oil. Threw the puller on, applied a good crank or two, tapped it on the side, and kaboom, she came off. Cleanest part of the engine is underneath the flywheel! I’ll degrease everything before I put it all back together. Cylinders are soaking in rust remover (doing those in a heat pro0f paint), new rings on the way, spark and fuel will be final pieces. My flywheel pulling was all part of my $35 engine breakdown.
      #281882
      T….in Wisconsin
        Thanks Ben,
        I’ll give the puller another try.
        #294078
        T….in Wisconsin
          Update 2/12/2025
          I had set removal the flywheel aside due to concerns of damage to the crankshaft using the double nut tool and smacking with a hammer.
          Fast forwarding to last night, the flywheel has been removed without any damage using a harmonic flywheel puller & 10-30 thread bolts.
          I’m convinced that by far this is the best methods to use.
          T.. in Wisconsin
