Home › Forum › Ask A Member › A tale of two magnetos
You are correct Scott. The throttle linkage should start moving when the roller aligns with the hash mark on the cam. You don’t have the choke closed do you? 😉
There is not cast in pointer on the FD model, only the bigger boys.
OK
