Home Forum Ask A Member A50 lower end noise
  • #1284
    GARY
      I was just moving an A50 I just started working on and was lifting it horizontally onto a bench.When I moved it I could here something sliding back and forth in the gear case area.It only moves a short distance as I tilt the motor back and forth.Sounds like something sliding on the shaft.I’m hoping it’s nothing serious but I need some expert advice before I take it apart and take a look.
      #14464
      George Emmanuel
        Is the shearpin missing? That would allow the prop to move back ‘n forth. If not, I’d pull the gearcase apart and see what’s going on..
        #14508
          I Agree, BIG RED FLAG!!!
          #14510
          dmbono
            Do you have the automatic exhaust cutout on the leg? There is a bullet that floats up and down, and may be moving when you laid the motor down.
