Home › Forum › Ask A Member › AC or DC
- This topic has 10 replies, 8 voices, and was last updated 8 years, 3 months ago by
mikesea.
December 5, 2017 at 8:59 pm #8802
Which type does a magneto based outboard produce? Our Wednesday group is meeting tomorrow and that is going to be one of the topics. Any suggestions on any tests to do to either prove or disprove? It should be an interesting Wednesday!!!
Thanks in advance.December 5, 2017 at 9:13 pm #68287Interesting topic indeed. First you need to ask AC or DC—where? At the spark? At the coil? or whatever. Actually, when it comes down to it, the answer is very complicated. A better topic would be on how the magneto produces a spark. You will then get into electricity generation, induced voltages, etc, etc.
December 5, 2017 at 9:57 pm #68289Anonymous
December 6, 2017 at 1:14 am #68294Very interesting, thanks Phil. At the risk of side tracking the OP… A question for Phil. Is it possible to superimpose the secondary circuit discharge on your second scan? Where would the ideal point of discharge occur relative to the big primary voltage spike? Perhaps this may be the ideal way to set the points in the magneto.
December 6, 2017 at 1:45 am #68299This is cool stuff,
Joe, they make a timing tool for the OMC and a wheel for the Merc to set the timing, the antiquers get set by ear….LOL
classicomctools@gmail.comDecember 6, 2017 at 1:50 am #68300Anonymous
I don’t know how I could do it. The "scope" is a toy, and only has one input. I imagine with a real(er) scope, with the points not connected, you could attach a second input to the points, and get two graphs: one showing the coil output, and the other where the points are open vs closed.
mine is the previous version of one like this:
https://www.adafruit.com/product/468December 6, 2017 at 2:11 am #68302Nice toy though. Just for the heck of it, It would be cool to play around and see what difference would show up in case of a leaky condenser, dirty points, etc. Obviously, dirty points would show up very clearly in missing/low spikes (I suppose)
December 6, 2017 at 2:48 am #68306I believe the second scope photo shows the resonant frequency (ringing) of the inductor/capacitor. A leaky capacitor is going to shunt and reduce the amplitude of the voltage spike and resonant voltage. It is my understanding that this ringing results in a longer spark plug arcing duration. A capacitor that has changed in value would result in a change in frequency of the ringing. By collection some data from known good coils and capacitors (resonant frequency and voltage amplitude) it should be fairly easy to figure if a capacitor is out of spec.
December 6, 2017 at 11:45 am #68309December 6, 2017 at 11:53 am #68310https://www.banggood.com/DSO138-DIY-Dig … rehouse=CN This was the DSO I was using & was around $30 Australian, & does require some assembling. I have found it quite usefull.
