Home › Forum › Ask A Member › Ad 11 Johnson
- This topic has 23 replies, 6 voices, and was last updated 1 year, 10 months ago by
fleetwin.
June 8, 2023 at 2:40 pm #276843
I picked up an Ad 11 Johnson…It has fire both cylinders…Rebuilt carburetor…It runs like a minute dies…after it sets a little bit..It will start back an does the same thing again..I put a different carb on it ..It still does same thing…The fuel tank I am using is good..use it all the time on other motors…I set the low an high speed 1 an half turns an 3/ 4 on other…It sounds good while running..Any ideas an help would be greatly appreciated..thank you
Donald Keller
June 8, 2023 at 4:21 pm #276846did you do all the electricals… did you vent the tank ? does is get to hot to touch ? is the water pump working ?
does it keep running if you pump the fuel primer button on the tank before it dies on you ??
did you clean the glass bowl filter element under the carb … ?? drill a few holes in it if to plugged up to clean
does the hose connector to engine leak fuel when you pump the primer
June 8, 2023 at 5:13 pm #276850Only electrical work I done, was clean points an new plugs.It has fire..I rebuilt one carb, and then put a different carb on it, both will run a minute an quit..I cleaned fuel bowl.connection for fuel line isn’t leaking,,, the preasure tank that I am using works good on other motors,,I have even used two different preasure tanks..Could the coils or condenser be dropping out..It’s got me..It just seems like it running out of fuel?
<!–more–>June 8, 2023 at 5:14 pm #276851Only electrical work I done, was clean points an new plugs.It has fire..I rebuilt one carb, and then put a different carb on it, both will run a minute an quit..I cleaned fuel bowl.connection for fuel line isn’t leaking,,, the preasure tank that I am using works good on other motors,,I have even used two different preasure tanks..Could the coils or condenser be dropping out..It’s got me..It just seems like it running out of fuel?
I also put new fuel lines on it to carbJune 8, 2023 at 5:20 pm #276852It is pumping plenty of water also..is not getting hot
June 8, 2023 at 5:35 pm #276853I also tried pumping primer button on tank…and it still quits,I even tried to pull choke half way,,still dies…
June 8, 2023 at 7:40 pm #276859Bad condensers will do that.
June 8, 2023 at 8:22 pm #276861see picture of problem areas if coils original they are likely cracked….best to redo all the electricals but try condensers first has suggested
June 8, 2023 at 8:48 pm #276863Ok…thakyou….Crosbyman…I will replace condemsers…an check points again…if that don’t work..I will replace coils…I will get back with you once I get it changed out..to let you know which one it was…thank you again for the help..I appreciate it
June 9, 2023 at 8:06 am #276872here is lots of good info on condensers and how problematic they can be…and how to test them properly with a home made test box.
https://wrcoutboards.org/wp-content/uploads/2020/04/Part1_Condenser_Construction_Failure_Modes.pdf
https://wrcoutboards.org/wp-content/uploads/2020/04/Part3_Sizing_Condensers_Correctly.pdf
https://wrcoutboards.org/wp-content/uploads/2020/04/Part4_Repairing_Broken_Condensers.pdf
