Home › Forum › Ask A Member › Ad 11 Johnson
- This topic has 23 replies, 6 voices, and was last updated 1 year, 10 months ago by
fleetwin.
June 9, 2023 at 9:28 am #276876
No idea what a Ad 11 Johnson is but I’m struggling with this
being an ignition problem. You say “coils & condensers”. If there is an
ignition for each cyl. it doesn’t seem likely both are dropping out & coming
back at exactly the same time unless there is some kind of ignition cut off
shutting down the motor. Fuel seem to be a more likely the issue. As you
have changed both the carb and the tank that leaves me to suspect what is
in between. My suggestion would be to take the fuel line off at the carb and
pump up the tank to see how much fuel you get.
Tubs.A "Boathouse Repair" is one that done without having tools or the skills to do it properly.
June 9, 2023 at 11:05 am #276879see list
June 9, 2023 at 11:12 am #276881good point yet he indicated the tank works fine on another motor
if electricals were never redone bad caps …both having reached a useful life are becoming prime suspects has suggestted by LLOYD
an easy inexpesnive decision after 66 years !
June 9, 2023 at 1:49 pm #276891
It would seem he has eliminated the tank
and the carb. as an issue. What I’m suggesting
is a test of the fuel system between the tank
connection and the carb. Possible blockage in
the line or an issue with the connector?
TubsA "Boathouse Repair" is one that done without having tools or the skills to do it properly.
June 9, 2023 at 3:43 pm #276893Did a 7.5 Evinrude a few months ago same symptons pulled the intake manifold off both gaskets were no good.Sticky and what was left of them blocked off a few of the little holes.Replaced both gaskets and it runs like new. Just a thought.Only takes 10 min to pull carb and intake off…..
June 9, 2023 at 5:23 pm #276896thank you crosbyman for the information an links on condensers, and all your help…I can use this….I put new condensers an new points in today…motor still runs like a minute then dies…I will have to order me some new coils for it.Hopefully new coils an wires will fix it ??
June 9, 2023 at 5:29 pm #276897Thank you Boathouse…I will pull fuel line of carb to see how much fuel is going through the line..I have another connector if that’s what it is..thankyou you again
June 9, 2023 at 5:33 pm #276898Thank you russ…I will check those gaskets also…will have to order the gaskets I guess..thanks to all of you for information
June 9, 2023 at 8:25 pm #276902coils are always a gamble… old coils get all cracked up and if yours show no indications of cracks (see pic) they may be good but…… yes they can react to heat although a minute run time does not genetate much heat to warm them up. Primaries ohms usually read a few ohms and secondary 4-8 Khoms depending on manuf.
plug wires can go open midway in a flex bend under the mag plate. which is also a good investment to put in new ones in
one condition that can impeded inflow of fuel is bad crankcase seals which will let air get sucked in instead of precious fuel from the carb… hopefully this is not your situation.
keep at it… patience brings joy… eventually 🙂
June 9, 2023 at 8:28 pm #276905cracked coils …. your’s are surely not that bad !! but they can fire to ground unded the unseen part …. touching the mag plate.
one thing you should check is presence or absence of sparks the moment it dies on you… loss of ignition sparks would confirm the cause .
if you do have good sparks (test quickly) fuel is likely still the main issue to chase down .
check the air nipple hose feeding air pressure to the side tank connector … make certain it is not cracked.
also check the small vertical hose on the side of the powerhead.
further down the road you may have to ckeck the check valves controlling/feeding crankcase pressure to the tank. they sit behing the intake maifold plate.
if your engine runs a minute it should have been able to build up “some” pressure in the tank …test by openning the tank cap quicly when it dies it should go pssst! as air escapes.
one test you can do after you pushed the primer button and started the engine is to lift the tank above the engine to gravity feed the fuel to it .
btw… did you ever do compression test on the cylinders ??
