Home Forum Ask A Member Advice on a DVA Peak Voltage Meter
  • #182997
    seakaye12
      I am looking for advice in preparation to purchase of a good DVA (Peak Voltage) meter….so I am able to properly test stators and switchboxes and the like. I currently have a Harbor Freight P98674 DVM. Perhaps I can add a DVA adapter to this or maybe I need to get a different meter with the feature built in. I would appreciate knowing what you use….and/or what you would recommend.
      Thanks, Chuck
      Harbor_600
      #183003
        Being old school, I never owned one back in the days when I was twirling wrenches for a living—-nor did any one else. But in more modern days things are better now. Anyhoo, I still don’t own a “real” one, but I did cobble up an adapter. The actual parts cost less than a buck, plus however fancy you want to get as far as a case, test leads, etc. The circuit floats all over the Internet. Here is one version. I will say that people go nuts over the capacitor, tending to use one that is way too big. The one I used is only 0.2 ufd and it works for me.
        dvacircuit
        • This reply was modified 5 years, 7 months ago by Mumbles.
        #183043
          I recently purchased this DVA adapter to use with one of my multimeters and I believe it max’s out at 400 volts which is enough for any CD ignition components I ever work on. I still haven’t used it so I can’t really say much about it except it was a cheaper way to go instead of buying a peak reading voltmeter.
          https://www.amazon.ca/gp/product/B0093U3TFG/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
          DVA-Adapter
          #183045
            My only question is since it plugs into the “COM” and “DCV” jacks on your multimeter, is there a standard spacing between the jacks?
            #183049
            crosbyman
              just a question …
              if PEAK Voltage is = AC + xx % can’t we just assume that any AC reading + xx% is good enough to estimate the peak value ?
              #183053
                One would think so, but it isn’t that simple. Depending on what you are testing, it may not be an AC sine wave (trigger sensors). Or you may be testing DC pulses (power pack output) etc, etc, etc
                #183058
                labrador-guy
                  I am also old school too! I don’t understand why you are looking at peek voltage. On small engines the faster it spins the higher the voltage. At one time high speed motors with lights would spin so fast that all lights hooked to it would burn out. Modern regulators cured that.
                  So keep your peek voltage high enough to make spark, that should work!
                  dale
                  #183064
                  seakaye12
                    Frank I made one too; I even think it works but I don’t really have all that much confidence in it so I thought it might be time to buy a commercially made one that people can vouch for.
                    And; yes….I hope the spacing is standard. I doubt it is though….one of the vendors for these seems to offer a special version for Fluke meters….and I bet that is because the spacing on theirs is different from what else is commonly used. They probably do that on purpose LOL…..
                    Chuck
                    • This reply was modified 5 years, 7 months ago by seakaye12.
                    #183065
                    seakaye12
                      So keep your peek voltage high enough to make spark, that should work!dale
                      Dale I think you are essentially correct but it is a diagnostic thing. If you don’t have spark you need to track back through the maze of $350.00 switchboxes and triggers and stators in an effort to identify positively which part is causing the problem. Otherwise you end up throwing expensive parts at it
                      Chuck
                      #183066
                        The Direct Voltage Adapter is used in conjunction with a multimeter for testing CD (Capacitor Discharge) ignition components, not points style magnetos as found in older motors. Specific values for stator and charge coil output are given in shop manuals along with values for testing ignition and trigger coils etc at both static and cranking/idling speeds. Testing CD ignition components individually helps to narrow down which component is at fault and eliminates the guesswork. I can already see the DVA coming in handy on the Merc/Mariner CD ignitions with the troublesome switch boxes.
