While on this subject of air cooled motors, I was using 16/1 mix from my OMCs when working on 69 Chrysler 3.5. Should I set aside a “special” gas can for 16/1 mix with “air cooled” oil for this motor or will it be ok with the TC-W3 oil I use in my old OMCs? Not a big deal to get a dedicated gas can but its cluttered enough with 8/1, 16/1, 24/1, 40/1, 50/1, 100/1, and pure gas tanks…and sometimes several of each.
My thoughts were having ENOUGH oil was probably the most important factor considering this motor was originally used with automotive oil and the modern oils, TC-W3 or modern “Air Cooled Motor” oil, should both be at worst adequate and more likely better than the original lubricant. I will probably use this motor 2-3 times a year for just a few minutes of putting around.
