Home › Forum › Ask A Member › Airguide Barometer Repair?
  • #205444
    mr-asa
      So, I’ve got this Airguide brand Marine Barometer that came with my boat and I need to take it apart to clean and restore as much of it as possible.
      I’m not sure how to separate the top and bottom portion. I have tried twisting to try and unscrew it with no success. I’m hesitant to try and pry the top off of it.
      Anyone have any insight?
      #205458
        No idea on how is comes apart, but at least it’s a “fair day”
        gjonz
          It’s friction fit, but with pitting might be a little challenging. If you can slightly heat that ring might help. If you break the glass, it can usually be found at a clock shop.
          Greg
          #205529
          mr-asa
            Thanks Greg, I’ll play with it and see what I can do
            #205544
            JOSEPH BRINCAT
              Cool,.. find. I had never seen the barometer. Many other Airguide instruments, speedo, clock, tach but not a barometer
              Joe
