Home › Forum › Ask A Member › Aluminum or stainless or brass…or galvanized
- This topic has 10 replies, 8 voices, and was last updated 4 years, 9 months ago by frankr.
July 25, 2019 at 5:01 pm #179479
I am fixing up a 14 Springbook footer (sears?) paid $100 (nice little rig for $100 for qwick trolling outings
transom backplates being replaced (2) 2 x 3 / 4 inch plywoods trim sealed in FB resin
what bolts should I use because aluminum bolts and nuts are not very common and I want to minimize electrolysis.. if that is a concern ?
July 25, 2019 at 7:09 pm #179480Google “Galvanic Series”. Ever wonder why stainless steel screws are so hard to get out of our aluminum outboards? It is because aluminum and SS are so far apart on the chart. It is the aluminum that corrodes in the presence of SS and forms that white powdery stuff that locks them together.. It may come as a shock to see that aluminum / steel are pretty close together and less vulnerable to galvanic corrosion.
July 25, 2019 at 7:25 pm #179482Interesting!
July 25, 2019 at 9:29 pm #179499ok no SS … galvanized ?
July 25, 2019 at 9:58 pm #179500zinc (galvanizing) and steel are both close to aluminum, but on opposite sides of aluminum. I’m not smart enough to know what to think of that.
July 27, 2019 at 10:47 am #180349I am not smart enough either, however, the Engineers that the Aluminum Boat Builders are. I don’t think you will go wrong following suit.
July 27, 2019 at 8:02 pm #180379All I can add is this . When aluminum siding was the rage , it was not to be installed with galvanized nails. If you did, within a few years the area where the nail contacted the siding would dissolve away and the siding would fall off. I was told it was called galvantic action that caused it. I use steel bolts I figure if its good enough for the bolts in the outboard motor ,should be good for the boat also. Just my 2 cents
July 28, 2019 at 9:07 am #180393Speaking of bolts! OMC bolts are some kind of alloy of stainless and steel. I went to my local recycle place a while ago. Had some stainless steel separate from other scrap metal. The yard worker whipped out his magnet and said “nope same as steel”. He gave me a line that if a magnet sticks to a metal it is not stainless. John/Evin/Gale all use good bolts that don’t seam to rust but a magnet does stick to them. Thought you might like to know that!
dale
July 28, 2019 at 10:41 am #180396Suppose you could Google “Metals Nobility Chart”. Yes, galvanic corrosion is always a concern within a corrosion cell. Brass might also be a material to try.
July 28, 2019 at 12:22 pm #180404Didn’t OMC use cadmium plated steel at some point?
http://www.omc-boats.org
http://www.aerocraft-boats.org -
