Home Forum Ask A Member Anodes on Evinrude 18 hp 1960
Viewing 9 posts - 21 through 29 (of 29 total)
  • #268276
      Sometimes I use Never-Seize on driveshaft splines into the power head.
      Should be no problem with that, correct?
      salnaes
        Thank you all for contribution to this discussion. I will follow Mumbles advice which seems to be confirmed by several of you. In addition I had a chat with a local mechanics here at my place yesterday who pointed out the fact that copper and aluminium is a bad combination. He strongly advice me not to use any sealer containing copper, since it will eat aluminium, as he said.
        I have Permatex Form-A-Gasket Aviation 3 in my workshop, so I will use this on the threads on both the two main bearing center bolts and on the eight sidebolts. Since several of the sidebolts are unavailable for 1/2” socket mounted on my torque wrench, it will be impossible to torque those bolts to the torque specs, so I have to use only my own feeling with a regular wrench. I dont have a crow foot, and it’s not possible to obtain 3/8” – 1/2” in our European metric world.
        On the crankcase flange I will use a thin layer of Loctite 518 anaerobic sealer. I will clean both flanges with aceton, and then use Loctite 7649 primer (spray can) on the flanges, let it air dry, and then apply a small bead on one of the flanges. I will avoid sealing the labyrinth grooves by the center bearing. I have tested the cover on the block, and it seems to fit perfectly without any gaps or movement. I might spread the sealer out on the flange surface with my finger. Some people put sealer on both flanges. I’m afraid of having to much sealer there, since it might squeeze inside the flange and possibly plug the labyrinth grooves and get into the crankcase where it shouldn’t be.
        So I was thinking of just make a thin and even layer on one of the flanges. Finally the two tapered pins are installed through the cover. Correct me if I’m wrong, but the thin part of the pin goes down through the hole in the cover and further into the block, right? With the pins installed I seal the threads on the 10 bolts and fasten them in the same manner as fastening the cylinder head bolts. I torque down to spec for those bolts that’s possible to torque. The remaining bolts I torque with a regular wrench due to the problems I mentioned above.
        Does this sound ok?
        #268286
        crosbyman
          di you download yourself a copy of the Johnson service manul to service your oldy ??
          #268291
          salnaes
            I bought Seloc 1956-70 Repair Manual which covers Johnson/Evinrude up to 40 hp 2-Stroke Models. I use this manual regularly as I work. But sometimes it does not give me a complete understanding on how to manage every task, although it’s a very good manual in general. Concerning the two tapered pins the instructions are a little uncertain to me, cause English is not my first language.
            #268292
              The taper pins help to properly align the 2 halves of the crankcase.   When reassembling the crankcase, insert the two taper pins and tap both of them into place before tightening the crankcase bolts.   The smaller end of the taper pins are inserted from the front (carburetor) side of the case toward the back (cylinder) side of the case.    If you have not already opened up the crankcase, you would do the opposite – drive the pins out from the back side toward the front.
              #268294
              salnaes
                Thank you Bob. You have now confirmed my assumption. I opened up the crankcase many months ago, but it took a very long time to get parts needed from the USA. Marineengine doesn’t sell to customers outside the USA / Canada, but finally I found out that many parts are the same in 1968, so that made it possible for me to order from Crowley Marine. Luckily I also found some retailers in Norway who had some of the parts I needed. Finally I did some purchases on ebay. After 6 months of investigation and work I managed to get all the parts I needed to perform a total overhaul of the complete outboard from 1960. The gearcase (Lower unit) and exhaust housing are  ready and totally rebuilt and waiting for the Power Head to be mounted. The same goes for Carburetor, Ignition system, Steering Handle and Hand Starter. So right now I try to figure out everything i need to know before I assemble the Power Head. Cylinders are honed, new pistons and rings installed, connecting rods are ready installed on the crank shaft, so next move now is to mount the Crank Case Cover. Now I think I’m ready to do that.
                Thanks for all advice and help.
                #268327
                crosbyman
                  go to MEMBERS ONLY tab  top right select :
                  INNERSANCTUM
                  LIBRARY
                  FIND GARRY SPENCER’S DROP BOX
                  go down his list of PDF’s  and pictures  etc… find the RED  JOHNSON SERVICE MANUAL
                  download and print locally   double sided   or  have a local print shop print the file from a USB key  … print double sided and spring bound  with plastic cover sheets
                  #268500
                  salnaes
                    Does anybody know what kind of outboard engine this is?old-engine
                    #268501
                    salnaes
                      old-engine
                      Here’s a picture of the old engine. Anybody familiar with this?
