Okay, I added some brand new 105 Lubriplate to the lower unit and got the old KD-4 running for the first time in 10-15 years. It pumps water really well so that was good.
What I am finding is it will run at the start setting and full throttle really well, but the idle adjustment isn’t letting it idle below about the start rpm.
I circled what I think is the idle adjustment needle on the picture below, and I think the needle is just a bit bent so it might not be seating perfectly. Is this most likely the correct diagnosis or am I way off?
If the needle is bent and wont let it idle at lower speeds is there any place like sierra that makes after market carburetor needles?
