Home › Forum › Ask A Member › Another coil substitution. Somebody may have done one already.
- This topic has 23 replies, 8 voices, and was last updated 5 years, 3 months ago by RICHARD A. WHITE.
January 6, 2019 at 8:21 pm #162090
I don’t think using these wires as laminates
was common so this may not be of much
value other than to show the versatility of
these OMC coils as a really inexpensive
($.00 in this case as they test good and the
Yankee in me can’t through them out)
substitute for earlier coils that have gone
bad and are no longer available.
- This topic was modified 5 years, 3 months ago by The Boat House.
January 6, 2019 at 10:02 pm #162106Well done Tubs, Nice tutorial.
2Fast4Me
January 6, 2019 at 10:06 pm #162107Amazing!!!!!
dale
January 7, 2019 at 8:57 am #162114I did a double OMC coil swap on a Caille, but had to reverse the orientation of the coils so the high tension aligned with the holes. When you do that, you must reverse the polarity of the primary wiring.
Wonderful tutorial! It is problem solving like what you displayed that makes our club such a valuable asset to the membership!
George
January 7, 2019 at 9:05 am #162115Wow!
A little information is a dangerous thing!
January 9, 2019 at 10:13 am #162452So what size capacitor will bff used with this configuration? Just wondering.
2Fast4Me
January 9, 2019 at 11:01 am #162457- This reply was modified 3 years, 2 months ago by The Boat House.
January 9, 2019 at 11:35 am #162458May seem insulting but don’t take it that way, Use the prick punch then use a center drill, this will start the hole where you want it, then you are left up to how sharp and how properly the drill is sharpened to determine if the hole will drill straight thru …or not… also use of a good cutting oil will also aid in your endeavors.
I was taught, many years ago, when hand drilling holes in a drill press to prick punch, then spin the center drill backwards by hand to get it as close as possible before turning the machine on to have the center drill cut. Should get you within .005http://www.richardsoutboardtools.com
classicomctools@gmail.com- This reply was modified 5 years, 3 months ago by RICHARD A. WHITE.
January 9, 2019 at 12:05 pm #162462- This reply was modified 5 years, 3 months ago by The Boat House.
January 9, 2019 at 12:19 pm #162464I did…. I replied to you on that…still at work trying to not get in trouble here..LOL
classicomctools@gmail.com -
