Home › Forum › Ask A Member › ANTIQUE OMC OUTBOARD IDENTIFICATION
Viewing 10 posts - 1 through 10 (of 21 total)
  • #9736
    keplerfan
      I just picked up this omc motor today. The serial number is 407208 3. The starter pulley says "outboard motors corp. It is an opposed twin that does not have a magneto. Instead, it has a setup like a Ruddertwin where you need a battery for spark.
      Any ideas?
      kees
        International Member
        model 407 is a Lightwin , year 1932 , 4 hp
        good luck
        #74731
        lyks2tinkr
          I have the 31 Elto Lightweight version of that motor. Great runner. I love the AK battery ignition sytem.
          #74733
            With that battery ignition I believe
            your motor is a Model 401 Lightweight.
            The punch doesn’t look like it was square on tag when stamped.
            #74746
            keplerfan
              When looking at it closer it does appear to be a 1 instead of a 7 but it is hard to tell . What is the difference in year?
              #74751
              keplerfan
                #74758
                kees
                  model 401 is from, 1931
                  its a Lightweight and also, 4 hp
                  btw.
                  I have a model 401 in my collection
                  and that has a flywheel magneto and has NOT a coil for battery ignition !
                  was that an option ?? your choice , I dunno.
                  #74801
                  keplerfan
                    It has an angle like a seven but on the bottom you can see what looks like the partial base of a one. baffling. is there another feature on this motor that could tell me what it is?
                    kees
                      Please, can you post a picture of the lower unit
                      and also of the backside of the power head with the muffler
                      then I can see if there is a difference between the flywheel magneto or the coil for battery ignition model
                      thanks
                      #74870
                      keplerfan
                        here is a pic of the exhaust manifold and lower…
