Home Forum Ask A Member Atom Red Ignition Module
Viewing 10 posts - 11 through 20 (of 43 total)
  • #236822
    bob-d
      Hey Joe, could you take a shot of the Kawasaki module mounted on one of your OMC’s ?
      Thanks.
      Bob D
      #236824
      joesnuffy
        I winter in St Pete Florida and I don’t have any motors down here but I will give you a link to a video that shows the how-to after I find it again.
        Joe
        #236825
        joesnuffy
          Here is the Kodi Bass video it took me a minute to find it. I love to watch his videos and when I saw this one I started using these modules their cheap and dependable. Its a wizard outboard but you will get the idea. I have learned a lot from his videos and I also watch This Old Outboards videos on youtube they are also a lot of great way to learn things and tips I didn’t know. They can be very funny also.
          https://www.youtube.com/watch?v=Y1CTdOD15AQ
          Hope that helps,
          Joe
          • This reply was modified 4 years ago by joesnuffy.
          #236830
          bob-d
            Great, thanks Joe.
            Bob D
            #236831
            joesnuffy
              Your welcome,
              Joe
              #237192
              bwanadon
                Thank you Joe! I’m going to try the Kawasaki’s.
                amuller
                  I can see using electronic modules if the stator plate is loose or the upper bearing worn, such that standard points don’t hold their setting. Absent that sort of issue, what is the advantage?
                  #237322
                    What is the advantage of Atoms over points and condensers? Zero maintenance, easier starting, better idling, accurate timing etc. and they should never need replacing. Once you’ve tried them, you’ll never go back.
                    #237365
                    rudderless
                      Once running, since 1970 first minibike, never lost a point ignition on any of my stuff. 4 years ago I went to the Atoms on my ’76 omc 15hp. Worked fine for half the summer. One fine day the wife and myself were 10 miles downstream when one Atom gave it up.
                      The Atoms do rob some output to the coil although I never noticed it. Long storage time is problematic for points and usually require a flywheel pull. I have used a 20 amp battery charger to try and revive the points without pulling the wheel when possible and has worked half the time.
                      #237382
                      amuller
                        It is annoying to have to pull the wheel to clean the points. On the other hand, I’ve seen lots of reports of aftermarket electronic modules failing.
