Home Forum Ask A Member Back Again / Spark / No Spark
  • #288748
    1956 Johnson QD-17 1-hp.
    Im to the point where im ready to  add fuel to this little motor.
    After checking for spark again , i have now lost it. I cannot understand WHY i can have spark then lose spark ?
    Could anyone offer any ideas why this is happening , i have cleaned the points ??
    Also what is best to use as a starting aide in the cylinders ?  Thank you. D
    #288767
    wedgie
      Have you done anything to the ignition system ? Cracked coils can cause intermittent spark.
      #288768
      Thank you , After making adjustments , i forgot to reset the coil / flywheel  mag.gap , they were touching.  Dang sometimes !  🙁
