Home › Forum › Ask A Member › Bang bang bang is not a good sound
You should be OK but don’t use reverse. will it go into reverse without the cables attached? 1 914 310 7086
Adjust the shift cable to push the shift linkage further into reverse.
I think he has no more adjustment.
Thanks guys. Correct, the cable seems to push the lever all the way back, though I can try it with the the cable removed
do so. if it goes into reverse then the problem is in the controls. if not then the problem is in the shift shaft most likely
Hey guys, just got my Motor back from the shop. My mechanic had a good lower unit, but now the reverse lock doesn’t work. 🙁
Any thoughts?
