Home Forum Ask A Member Best cork carb float coating
Viewing 10 posts - 21 through 30 (of 46 total)
  • #15868
    archangel
      Here’s Red Kote’s tech sheet and instructions:
      http://damonq.com/TechSheets/Red-Kote.pdf
      #15879
        I bought the Aero Gloss and tried that last year.
        The first float, after an hour of run time, lost all of the coating, and the slimy gel like substance that was left clogged itself all through the carb.
        Maybe I didn’t wait long enough to dry? I waited about 4 days. Maybe wasn’t clean enough?
        Dunno, but now Im scared to try again.
        #15887
        crosbyman
          I had no troubles with aero gloss…but in any event I now use dollar store crazy glue …
          #15924
          legendre
            quote Phil B:
            Any prep of the insides first?
            If you’re referring to the inside of the fuel tank, then that’s a big "no" – not required.
            (Unless the tank is leaking, of course – which is an entirely different matter.)
            #68322
            camaroman
              old thread but por-15 tank sealer is a current product.used it inside boat tank, works fantastic. Didn’t even prep or anything, just cleaned real well. Left to dry a week in hot SoCal summer.
              Have a bunch left, will use on the tanks and float for my 48 elgin and 53 seabee 🙂
              #68324
              outbdnut2
                I’ve had aerogloss airplane dope not adhere well to any original coating that’s on the float. Had it flake off on two out of about 20 motors I used it on so I don’t use it anymore.
                crosbyman
                  quote Archangel:
                  Are there any Canadian members out there who know where, or if, Red Kote is available in Canada?
                  try contacting the company web site ask for canadian dealers
                  #68339
                  vintin
                    I coated a float with POR-15.
                    The POR-15 shriveled up and peeled up causing the float to rub the side of the carb.
                    I would not suggest using it to coat floats.
                    You may just end up like me.
                    On the rope.
                    #68351
                    brian
                      I’ve had success with Seal All, widely available and not expensive. Use MEK to thin it or clean an area before sealing. So far no problems but I don’t leave gas in a carb for long periods of time. Dries fast. I even used it to seal a Martin 20 two piece gas tank. It didn’t leak, but as stated, I don’t leave gas in tanks and carbs for a long time.
                      #68402
                      camaroman
                        VinTin – that sucks man! Ive read of one or 2 folks who have had this happen, however it seems many people have very good results. I think one issue is the old fuel absorbing into the cork and leaving behind a varnish residue which might cause this. I read on a vintage outboard site that he used por-15 many times with great success but pointed out there could be issues with old varnish on the cork.
                        Anyway – thanks for the update and sorry to hear! I might try some on fresh cork and soak it in 87 gas for a few days – Did u let it dry for 3-4 days minimum before using?
